Introduction: Solar Lamp
I made a solar jar that is meant to be placed in a backyard garden for aesthetic purposes.
I used scissors, a permanent marker, drill, tin jar, steel foil tape, solar light, and galvanized metal wire.
Step 1: Sealing the Jar
Wrap the outside of the tin jar in the steel foil tape.
Step 2: Designing Pattern
Outline the pattern of holes on the jar and drill them in the jar. This is where the light will shine out of.
Step 3: Inserting Solar Light
Cut out the top of the jar and put the solar light where the hole is. Once in place, tape in down to secure it.
Step 4: Making Handle
Drill two more holes in the sides of the jar and then run the wire through it. Bend the wire in a hook shape when you put it in the jar so that it stays in place. It is now finished.
