Solar Power Bank Using Old Laptop Batteries
Intro: Solar Power Bank Using Old Laptop Batteries
Hi All,
In this instructable, I will share how to make a Solar Power Bank using a Kit and old Laptop batteries
This kit was bought from Aliexpress. The power bank has a led panel that can be used for camping. so good builtin power bank and light combination
STEP 1: What Do We Need ?
- Solar Power bank kit from Aliexpress (https://a.aliexpress.com/_d8ypnQv )
- Old Laptop Battery
- Multi meter
- Soldering Iron
- Wires
STEP 2: Extract Batteries
I have extracted my batteries from old laptop battery
- Gently break open the outer shell
- Carefully disconnect batteries from circuit and each other
- Test battery voltage, it should be above 3v
I have used batteries that were around 2.5 v and yet worked fine
STEP 3: Battery Pack
- To make the battery pack we need 4 cells connected in parallel
- Remember to use thick copper wire
- Do not overheat the batteries while soldering, take breaks if needs
STEP 4: Assembly
- On the main PCB, we have following, clearly marked
- Battery ( B+ and B-)
- Solar+ and Solar -
- Led+ and LED-
- This makes is extremely simple.
- Just solder the respective wires on the PCB
- You may have to secure panels and batteries using tape or hot glue
- Always before closing, test every thing
STEP 5: Close It Up
- The outer case needs to be secured with extremely tiny screws..
- Once done, charge the power bank full and then using USB doctor to test the actual capacity
- Solar Panel, does not really do much
- The LED panel is good for camping or emergencies
