Introduction: Solar Powered Gyroscope
Gyroscope is a real cool device. Its action is a work of art. When you look at it deifying earth gravity you cannot stop that feeling of fascination.
Today I'm trying to make a new project.
I wanted to make the Gyroscope cooler. I wanted to add a little bit of green energy to it so I can have The Solar Powered Gyroscope.
Here is my Channel on Youtube:
AeroArduino
Step 1: Components
Step 2: Assemble and Test
Disassemble the solar car
I disassembled the Solar Car to get the motor and solar panel out from it. Then I tested the solar panel with the motor.
Assemble
Connect a larger gear to the motor.
Tape the motor to the Gyroscope frame. Make sure that the motor can rotate freely. Adjust the gear to be gently coupled with the Gyroscope gear.
Test
I tested the Gyroscope in the direct Sunlight. The Gyroscope started to rotate slowly at the beginning but after a while it seemed to gain momentum and the speed increased as shown in the video.
Step 3: Adding a New Solar Panel
I decided to add a Solar panel to increase the rotation speed of the Gyroscope.
It worked and I really noticed a difference in rotation speed.
Unfortunately, the Gyroscope hasn't been rotating in its full speed which gives it Rigidity.
So it was unable to standalone and keep its position like a full functioning Gyroscope.
However, I've learned from this experiment and new some tricks that can make me create future projects.
Thank you for reading my instructable...
Do you like audio books and want to learn something new on the Go ?
This instructable is brought to you by Audible, the famous Audio Books Platform. You can now listen to free Audio Books from Audible.
Listen to Free Audio Books on Audible US ...
Listen to Free Audio Books on Audible CA ...
Listen to Free Audio Books on Audible UK ...
Listen to Free Audio Books on Audible DE ...
Listen to Free Audio Books on Audible FR ...
That's all. Thank you for reading.
Here are some of my latest books on Amazon.
