Introduction: Soldering Fume Extractor
I've made an extractor for soldering fume.
Material used:
  • Plastic Bottle
  • Fan
  • Plastic tube
  • Power supply
  • Iron bars and angle
  • Bolts and nuts
Tools:
  • Cutter
  • Glue gun
  • Driling machine
Step 1: Cut the Bottom of the Bottle
Use the cutter to cut the bottom of the plastic bottle.
Step 2: Fan Insertion
Please take care to air flow direction
Step 3: Wire Window
Cut the side of the bottle to allow the cables to enter
Step 4: Wire Connect
Connect the power supply to the fan. Check voltage and current supply.
Step 5: Fan Sealing
Seal the edge of the fan with the glue gun.
Step 6: Cut the Cap and Insert the Tube
Measure tube diameter, cut the cap and insert the tube.
Step 7: Support Assembly
Assembly some iron bars to provide a stable support to the the fan, or use the bottle handle.
Step 8: Final Result
The soldering station is ready to be used, free of smoke.
