Introduction: Soldering Iron Stand From Copper Pipe
Here's a quick and easy soldering iron stand.
Step 1: Cut Pipe.
You will need: Copper pipe. Saw. Flat piece of wood. Rubber sheet. Glue. Clamp. Wood screws. Drill. Hammer or vice.
Find some copper pipe just large enough for your soldering iron to go in. Note the iron may have a screw on the side.
Saw off a section of pipe. De-burr any sharp edges.
Step 2: Crush and Drill
Hammer the pipe flat, (or crush in a vice) from one end up to the point where the iron will go most of the way in from the other end, but the hot pipe cannot touch the plastic body of the iron.
Bend the pipe up a little and clamp the flat end to the piece of wood centrally laterally, and at the far end lengthways. Drill holes smaller than the screws through into the wood. Drill again just through the pipe with a drill larger than the screws. Fix with screws. If they go through, remove, saw off the ends, and re-fit.
Step 3: Underside
Glue pieces of rubber to the underside of the base for grip to your workbench. I used rubber plumber's tape, but cycle inner tubes would work too.
Place your soldering iron in the end, and bend up the pipe until the iron is nicely balanced. Bear in mind the weight of the cable, which may swing about in use.
Voila! Note this stand will get hotter than a proper spiral stand, so wait for it to cool after use.
3 Comments
2 years ago
As the saying goes, great minds think alike!
I had this exactly same idea a few years ago.
A pice of scrap wood, a hammer, 2 small nails and a piece of scrap 1/2 inch copper pipe. A couple of hammer whacks to the pipe to flatten and bend one of the ends, nail it down to the wood, and voila! The best and sturdiest soldering iron holder I ever had!
It is so simple it is nothing short of genius!
2 years ago
Thats a good idea . Move the screws further apart for better support
The problem I often have with my irons in spring type holders is that the cord can fall into the spring coils and burn.
Here the same could happen too so I'm wondering what could be done to shield the outer surface down where the tip would heat it up.Perhaps a bit of ceramic fibre insulation from an old microwave or stove? That would keep the tip hotter too. Hmm.
2 years ago
Clever way to reuse scrap copper pipe
