Introduction: Solve a Rubiks Cube the Wrong Way
Solve a rubiks cube so that you can start. Pleasebe nice this is my first Instructable if you have any questions leave comments.
Step 1: Opening the Cube
Turn any of the faces 45 degrees either way. (1/4 turn)
Step 2:
Take a flat head screw driver and pop out the middle square on the 45 degree angle. In this case it is the yellow and green ones.
Step 3: Take the Pieces Off
Take all of the pieces which should now be loose off. You should be left with something like the photo below.
Step 4: Sort the Colors
Sort all the borders and start with one side working away from the floor or working surface. Make sure your pieces are facing the correct sides otherwise you will be in the same problem as before. Before heading to the next section make sure everything is in the proper place.
Step 5: DISCLAIMER
I am not in anyway responsible for you ruining your cube. Following through with this instructable is voluntary and chose to be done by you. Enjoy!
