Introduction: Some Simple OS X Command Line Tools for Everyone
Some Simple OS X Command Line Tools For Everyone
These were gathered from around the internet and from my personal knowledge. Many are simple tools that one can read about in the MAN pages, a couple are shell items that you can create on the fly. Enjoy.
This first one is a simple tree structure directory listing. First go to the command line on your mac by opening the terminal app.
at the prompt cd to home if you are not there.
$ cd ~
Next lets edit your .profile which is basically your shell control panel. We are going to create an alias.
$ vi .profile
This will put you into the editor you ‘i’ to start inserting. Most of you will have a blank file, some of you might already have items in here.
In your file put the following.
alias dirtree="ls -R |grep ":$" | sed -e 's/:$//' -e 's/[^-][^\/]*\//--/g' -e ’s/-/|/'"
Hit escape, hit wq at the : to write.
Now lets source the .profile to read in the alias.
$ source .profile
Now you can type the command and see the tree output.
$ dirtree
|---------------colorpicker
|-------------js
|---------------shortcode-generator
|-----------------js
|-----------------shortcodes
|-----------images
|-----------includes
|-------------js
|-----------lang
|-----------psd
|—————styles
It gives you an easier to read directory structure.
This next one I use quite frequently, it allows one to copy information to and from your clipboard. These are simple command line tools and you can MAN page them for more information.
PBCOPY & PBPASTE
$ ls -al | pbcopy
Will copy the directory listing to the clipboard.
$ pbpaste >> filename.txt
Will now paste the directory listing from the clipboard to a filename.txt file.
DISKUTIL
Most of you know you can access diskt utility form the applications area, but did you know you can perform the same functions from the command line.
$ diskutil
Will show you the full list of options and of course read the MAN pages before you go messing with your disks.
A quick example I found is over at http://www.ernieflores.net
Deleting and merging a partition with diskutil from the command line
Launch the Terminal and type the following into the command line:
$ diskutil list
#: TYPE NAME SIZE IDENTIFIER
0: GUID_partition_scheme *120.0 GB disk0
1: EFI 209.7 MB disk0s1
2: Apple_HFS Lion 119.2 GB disk0s2
3: Apple_Boot Recovery HD 650.0 MB disk0s3
Look for the identifier for the partition you do not want. We are going to use disk0s3.
To remove that partition type.
$ diskutil eraseVolume HFS+ Blank /dev/disk0s3
The partition will be erased.
$ diskutil mergePartitions HFS+ Lion disk0s2 disk0s3
This will merge the two partitions.
This next two are fun to play with but not much more.
BANNER
This will print a ascii text banner of whatever input one gives it.
$ banner -w 30 joe
You can also pipe this to the printer.
$ banner -w 20 JERRY > jerry | lp -d "_132_235_132_250" jerry
This will send banner the word jerry at 20 width, put it into a file, then print the file.
You can get a list of printers with
$ lpstat -a
and
$ lp -d “printername” file
prints from the command line.
SAY
Say will make your computer say some text string. It is great for playing with and having fun with your friends.
$ say hi
Will make your Mac say the word “Hi”.
The last one is very powerful and allows you to do many things on your Mac from the command line.
SYSTEMSETUP
$ sudo systemsetup
will get you there. Some of the options you can try are
Usage: systemsetup -setrestartfreeze
Set restart on freeze to either or .
Usage: systemsetup -getallowpowerbuttontosleepcomputer
Display whether the power button is able to sleep the computer.
Usage: systemsetup -setallowpowerbuttontosleepcomputer
Enable or disable whether the power button can sleep the computer.
Usage: systemsetup -getremotelogin
Display whether remote login is on or off.
Type -help in systemsetup to see all of your options. Sometimes this is a quick way to set something when you are a heavy command line worker.
These are just a few of the tools you can use, there are 1000’s more but I wanted to show you a few that I use to get things done.
Enjoy
Joe Murphy
AKA Grehyton
