Sonar Collar for Blind Dogs
9,658
47
25
Introduction: Sonar Collar for Blind Dogs
About: Electrical Engineer
This project features a collar intended for use with visually impaired canines. An ultrasonic sensor hangs below the collar and senses when an object is close and emits an audible beep warning the dog that they should proceed with caution. The overall design makes it so that the dog is not uncomfortable wearing the device (it hardly weighs anything at all) and it doesn't impede their movement.
Step 1: Parts
You will need:
An Arduino (I used an UNO) with i2c capabilities
A small speaker
Male header pins
PCB
NXT Sonar Sensor
NXT Wire connector
9v Battery
External Power for the Arduino (There are many options to use)
Dog Collar
Hot glue gun
Soldering Iron
Step 2: Hardware Assembly
The first thing we're going to do is breadboard everything to make sure it's all functioning properly. We'll get to making things permanent later on...
The first step is to strip one end of the NXT wire to expose the 6 colored wires. Connect them as follows or use the diagram provided.
White +9V
Black GND
Red GND
Green +5V
Yellow SCL and clockPin(12)
Blue SDA
Speaker GND and 13
Step 3: Software
The first step to getting the program to work is to open a new text document and paste the following:
#ifndef _I2CMASTER_H
#define _I2CMASTER_H   1
* Title:    C include file for the I2C master interface
*           (i2cmaster.S or twimaster.c)
* Author:   Peter Fleury <pfleury@gmx.ch>  http://jump.to/fleury
* File:     $Id: i2cmaster.h,v 1.10 2005/03/06 22:39:57 Peter Exp $
* Software: AVR-GCC 3.4.3 / avr-libc 1.2.3
* Target:   any AVR device
* Usage:    see Doxygen manual
#ifdef DOXYGEN
 @defgroup pfleury_ic2master I2C Master library
 @code #include <i2cmaster.h> @endcode
 @brief I2C (TWI) Master Software Library
 Basic routines for communicating with I2C slave devices. This single master
 implementation is limited to one bus master on the I2C bus.
 This I2c library is implemented as a compact assembler software implementation of the I2C protocol
 which runs on any AVR (i2cmaster.S) and as a TWI hardware interface for all AVR with built-in TWI hardware (twimaster.c).
 Since the API for these two implementations is exactly the same, an application can be linked either against the
 software I2C implementation or the hardware I2C implementation.
 Use 4.7k pull-up resistor on the SDA and SCL pin.
 Adapt the SCL and SDA port and pin definitions and eventually the delay routine in the module
 i2cmaster.S to your target when using the software I2C implementation !
 Adjust the  CPU clock frequence F_CPU in twimaster.c or in the Makfile when using the TWI hardware implementaion.
 @note
    The module i2cmaster.S is based on the Atmel Application Note AVR300, corrected and adapted
    to GNU assembler and AVR-GCC C call interface.
    Replaced the incorrect quarter period delays found in AVR300 with
    half period delays.
 @author Peter Fleury pfleury@gmx.ch  http://jump.to/fleury
 @par API Usage Example
  The following code shows typical usage of this library, see example test_i2cmaster.c
 @code
 #define Dev24C02  0xA2      // device address of EEPROM 24C02, see datasheet
 int main(void)
     unsigned char ret;
     i2c_init();                             // initialize I2C library
     // write 0x75 to EEPROM address 5 (Byte Write)
     i2c_start_wait(Dev24C02+I2C_WRITE);     // set device address and write mode
     i2c_write(0x05);                        // write address = 5
     i2c_write(0x75);                        // write value 0x75 to EEPROM
     i2c_stop();                             // set stop conditon = release bus
     // read previously written value back from EEPROM address 5
     i2c_rep_start(Dev24C02+I2C_READ);       // set device address and read mode
     ret = i2c_readNak();                    // read one byte from EEPROM
     i2c_stop();
     for(;;);
 @endcode
#endif /* DOXYGEN */
#if (__GNUC__ * 100 + __GNUC_MINOR__) < 304
#error "This library requires AVR-GCC 3.4 or later, update to newer AVR-GCC compiler !"
#endif
#include <avr/io.h>
/** defines the data direction (reading from I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_READ    1
/** defines the data direction (writing to I2C device) in i2c_start(),i2c_rep_start() */
#define I2C_WRITE   0
 @brief initialize the I2C master interace. Need to be called only once
 @param  void
 @return none
extern void i2c_init(void);
 @brief Terminates the data transfer and releases the I2C bus
 @param void
 @return none
extern void i2c_stop(void);
 @brief Issues a start condition and sends address and transfer direction
 @param    addr address and transfer direction of I2C device
 @retval   0   device accessible
 @retval   1   failed to access device
extern unsigned char i2c_start(unsigned char addr);
 @brief Issues a repeated start condition and sends address and transfer direction
extern unsigned char i2c_rep_start(unsigned char addr);
 If device is busy, use ack polling to wait until device ready
 @return   none
extern void i2c_start_wait(unsigned char addr);
 @brief Send one byte to I2C device
 @param    data  byte to be transfered
 @retval   0 write successful
 @retval   1 write failed
extern unsigned char i2c_write(unsigned char data);
 @brief    read one byte from the I2C device, request more data from device
 @return   byte read from I2C device
extern unsigned char i2c_readAck(void);
 @brief    read one byte from the I2C device, read is followed by a stop condition
extern unsigned char i2c_readNak(void);
 Implemented as a macro, which calls either i2c_readAck or i2c_readNak
 @param    ack 1 send ack, request more data from device<br>
               0 send nak, read is followed by a stop condition
extern unsigned char i2c_read(unsigned char ack);
#define i2c_read(ack)  (ack) ? i2c_readAck() : i2c_readNak();
#endif
Save the file as i2cmaster.h
Next open up the Arduino software and create a new program with the following code:
byte clockPin = 12;
byte buf[9];//Buffer to store the received valeus
byte addr = 0x02;//address 0x02 in a 8-bit context - 0x01 in a 7-bit context
byte distance;</p><p>void setup()
  i2c_init();//I2C frequency = 11494,253Hz
  Serial.begin(9600);
  printUltrasonicCommand(0x00);//Read Version
  printUltrasonicCommand(0x08);//Read Product ID
  printUltrasonicCommand(0x10);//Read Sensor Type
  printUltrasonicCommand(0x14);//Read Measurement Units
  pinMode(13,OUTPUT);
  </p><p>void loop()
  //printUltrasonicCommand(0x42);//Read Measurement Byte 0
  distance = readDistance();
  if(distance == 0xFF)
    Serial.println("Error Reading Distance");
  else
    Serial.println(distance, DEC);
  if(distance<30){
    tone(13,4000);
    delay(200);
    noTone(13);
byte readDistance()
  delay(100);//There has to be a delay between commands
  byte cmd = 0x42;//Read Measurement Byte 0
  pinMode(clockPin, INPUT);//Needed for writing to work
  digitalWrite(clockPin, HIGH);
  if(i2c_start(addr+I2C_WRITE))//Check if there is an error
    Serial.println("ERROR i2c_start");
    i2c_stop();
    return 0xFF;
  if(i2c_write(cmd))//Check if there is an error
    Serial.println("ERROR i2c_write");
    i2c_stop();
    return 0xFF;
  i2c_stop();
  delayMicroseconds(60);//Needed for receiving to work
  pinMode(clockPin, OUTPUT);
  digitalWrite(clockPin, LOW);
  delayMicroseconds(34);
  if(i2c_rep_start(addr+I2C_READ))//Check if there is an error
    Serial.println("ERROR i2c_rep_start");
    i2c_stop();
    return 0xFF;
  for(int i = 0; i < 8; i++)
    buf[i] = i2c_readAck();
  buf[8] = i2c_readNak();
  i2c_stop();
  return buf[0];
void printUltrasonicCommand(byte cmd)
    i2c_stop();
    return;
    i2c_stop();
    return;
  i2c_stop();
  delayMicroseconds(60);  </p><p>  if(i2c_rep_start(addr+I2C_READ))//Check if there is an error
    i2c_stop();
    return;
  i2c_stop();
  if(cmd == 0x00 || cmd == 0x08 || cmd == 0x10 || cmd == 0x14)
      for(int i = 0; i < 9; i++)
        if(buf[i] != 0xFF && buf[i] != 0x00)
          Serial.print(buf[i]);
        else
          break;
  else
    Serial.print(buf[0], DEC);  </p><p>  Serial.println("");
' Wires on NXT jack plug.
' Wire colours may vary. Pin 1 is always end nearest latch.
' 1 White +9V
' 2 Black GND
' 3 Red GND
' 4 Green +5V
' 5 Yellow SCL - also connect clockpin to give a extra low impuls
' 6 Blue SDA
' Do not use i2c pullup resistor - already provided within sensor.
*/</p>
Verify and Compile the code onto your Arduino. If you get an error make sure that the i2cmaster.h file is accessible by the Arduino code.
You can adjust the distance from which the beeping will occur by lowering or raising the value in the if(distance<30) condition.
Step 4: The PCB
Now is the time where you've tested everything and it's time to put it into a more permanent state. Start by soldering the male header pins in a way that the PCB can easily clip onto the Arduino. Take your time soldering in the connections making sure that you don't create any short circuits. After you have soldered the main connections together cover the more flimsy connections to the wires with hot glue. After this, hot glue the speaker to the top and solder those wires into place. Refer to the pictures for a better understanding of what is should roughly look like.
Step 5: Mounting the Sensor
Before proceeding have a look at the collar and decide the best way to attach the sensor for the height and comfort-ability of your dog. I ended up hot-gluing the sensor so that gravity would always keep the sensor pointed forward no matter what.
When you've mounted the sensor, attach the rest of the system to the collar making sure to leave room for the dog's head to be inserted and removed from the collar.
At this point, you should have a fully functional sonar collar for your dog and after hooking up the external power supply so that free movement is able, you're ready to go!
Automation Contest 2016
Runner Up in the
Dog Challenge 2016
Grand Prize in the
Dog Challenge 2016
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
    25 Comments
    morrispr1
    morrispr1
    6 years ago
    Thank you for the response! Yes, I have placed the .h file in every directory that I found the Arduino code in. It does actually show up on a second tab in the Arduino code window when I open the .ino file, which I saved on the first-to-fourth attempts at loading (default filenames). Copied and pasted the code (retried several times) as listed on this post, but still get the same error when Verifying:
    C:\Users\Paul\Documents\Arduino\sketch_dec30b\sketch_dec30b.ino:1:23: fatal error: i2cmaster.h: No such file or directory
    compilation terminated.
    exit status 1
    Error compiling for board Arduino/Genuino Uno.
    Thank you again. We are so hopeful to help Amos.
    Kid regards,
    Paul
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    Hi all, I am new to this, I am desperate to get this working for my dog just suddenly went blind. I have it all wired up using a NANO board that I had. I have the same issue as above.
    Eric_Hill
    Eric_Hill
    Reply 1 year ago
    You can try formatting your include line to the file path instead if it's having a hard time finding it
    Ex.
    #include "C:\Users\buildmyhobby\Documents\Arduino\libraries\i2cmaster\i2cmaster.h"
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    Thanks Eric, not sure why but couldn't get it working. I found this one :
    https://rees52.com/diy-arduino/4339-make-an-obstac... a
    and it worked first go. I'm now trying to improve it so it recognises that the dog has lay down and doesn't continue triggering.
    I appreciate your efforts trying to help me. My background id PLC programming in Siemens and Mitsubishi, but I now have to learn Arduino I love its adaptability.
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    Eric one question. You use a speaker in yours. How did you go with creating tones. I was trying to create High Frequencies of 20khz and above so it doesn't get annoying for humans? I trying with a piezo buzzer, but I don't think it is working how I intend. I think I will have to go back to lower frequencies and volume control it.
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    Hi Eric, thanks for the reply. I have overcome the first error.
    Now I am getting the following:
    12cmaster:6:15: error: expected unqualified-id before '<' token
    12cmaster:16:3: error: expected unqualified-id before '<' token
    </p><p>void loop()
    C:\Users\KevB\Documents\Arduino\libraries\12cmaster\12cmaster.ino: In function 'void printUltrasonicCommand(byte)':
    12cmaster:101:27: error: expected primary-expression before '<' token
    12cmaster:101:28: error: expected primary-expression before '/' token
    12cmaster:101:29: error: 'p' was not declared in this scope
    12cmaster:101:31: error: expected primary-expression before '<' token
    12cmaster:101:36: error: expected primary-expression before 'if'
    12cmaster:123:33: error: expected primary-expression before '<' token
    12cmaster:123:34: error: expected primary-expression before '/' token
    12cmaster:123:37: error: expected primary-expression before '<' token
    C:\Users\KevB\Documents\Arduino\libraries\12cmaster\12cmaster.ino: At global scope:
    12cmaster:135:3: error: expected unqualified-id before '<' token
    */</p>
    exit status 1
    I get this when I verify and compile the sketch. From my understanding this process is to check for sketch errors? If this is correct, I believe your sketch is working with no errors, is there a way to upload it without doing verify/compile? I tried by pressing upload but it wouldn't do it? Not sure if this is possible? Sorry for asking all this, but I want to build this for my dog, he went blind unexpectantly. I have never used Arduino before, so this is a need from necessity for me. My background is in PLC - logic programming, I will have to learn a bit more about Arduino programming now.
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    This is the files I created and in Arduino IDE
    Eric_Hill
    Eric_Hill
    Reply 1 year ago
    Looks like there are some formatting issues. Try re-copying the code
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    Thanks Eric. will do
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    Hi Eric thanks for the response. I did work the library placement but now I am getting the following:
    </p><p>void loop()
    */</p>
    exit status 1
    If possible could you post a video showing the whole procedure as this may show up what I am doing wrong instead of bugging you? I appreciate your help. This collar should really make a difference to my dog. The dog in the image you used is an identical to my last dog, she was beautiful.
    buildmyhobby
    buildmyhobby
    Reply 1 year ago
    HI Eric,
    I now get the following:
    </p><p>void loop()
    */</p>
    exit status 1
    I was thinking if possible are you able to upload a video showing the process from saving your code to verify/compile this should show me where I am going wrong and shouldn't have to keep asking you questions.
    Is the dog you used your dog? My last dog was an identical twin, she was beautiful. I have an AmStaff and a WhippetXKelpie which is the one that went blind. Poor bugger was seeing, his heart valve decided to play up and caused him hopefully help to go blind overnight, this collar will help stop him running into things. He currently has a wound on his eye and the vet said if he bumps into things and does more damage to them, they are going to have to remove his eyes. I hope to stop that happening.
    Kramlevocs
    Kramlevocs
    Question 3 years ago on Introduction
    Thanks for posting this Eric. Does your dog use this all the time? What about when laying down or caged? What mfr/part number speaker did you use?
    Chrome98
    Chrome98
    6 years ago
    I'm concerned about driving the dogs crazy since they can hear sound in the ultrasound range. Other than that the concept is great. I think I'll try the same with an infrared obstacle sensor.
    Eric_Hill
    Eric_Hill
    Reply 6 years ago
    On the contrary, although it outputs around 40khz (which is indeed in the dog's hearing ability although it's at the very high point) the bursts are extremely small and directional. Unless the sensor is pointed directly at the dogs ears (which it is not) they will not be able to hear the sound since even a quiet room will cover up whatever indistinguishable frequencies may be redirected toward the dog.
    paulpropst
    paulpropst
    Reply 3 years ago
    My company has made a commercial prosthetic SONAR unit for BlindDogs since 2015. Our smallest weighs 44 grams all up with battery installed (1+year battery life) This Instructable may be used by dogs that cannot hear..so that's a big plus. For dogs that can hear let me say this. Keep the pulse down to microseconds and don't use a transducer frequency UNDER 40khz. With any ultrasound gear make sure your pulses sre as brief as possible to prevent freaking the dog out! Of course, if the dog can't hear that's not a probelm....just make the thing vibrate. Unfortunately, vibrator motors REALLY chew up the battery life!!
    Chrome98
    Chrome98
    Reply 6 years ago
    Cool. thanks.
    morrispr1
    morrispr1
    6 years ago
    How do I "make the i2cmaster.h available to the Arduino code."? Placed file in same directory as all copies of the sketch that were made for this and still get error 'No such file or directory' Otherwise this is coming together as designed Thank You! Have a 9.5yo boxer that went blind shortly after rescuing him. Hoping to help him 'see' again!
    Eric_Hill
    Eric_Hill
    Reply 6 years ago
    Sorry for the late response. It should show up if you have it in the same directory as the program file. Maybe try restarting Arduino. If that doesn't work let me know and I'll look deeper into it.
    Battlespeed
    Battlespeed
    6 years ago
    You should look into marketing this idea commercially. In fact, I can easily see you getting funding on Shark Tank or any of the crowdfunding sites with this!
    Battlespeed
    Battlespeed
    Reply 6 years ago
    ....or, show it to your veterinarian. He might want to dump some cash into such a project.
