Introduction: Space Invaders on RasPi With OLED and Capacitive Touch
This project implements Capacitive Touch to a Space Invaders game that runs on a Raspberry Pi.
Step 1: Things Used in This Project
Hardware components
- Raspberry Pi 2 Model B x 1
With Power Supply and SD card loaded with Raspbian - XinaBox OD01 x 1
- XinaBox BR01 x 1
- XinaBox SH01 x 1
- XinaBox XC10 x 1
Step 2: Story
With no requirement for soldering, wiring or any specific hardware knowledge, we click together a Space Invaders game played on a RasPi with a OLED display and a Capacitative Touch panel.
Watch this video first - it first shows how the hardware is clicked together.
Click together a Space Invaders game for the Raspberry Pi
Step 3: Preparation
- Click together the hardware as per the above video.
- Install the LUMA OLED library, by following these instructions: https://luma-oled.readthedocs.io/en/latest/intro.html and https://github.com/rm-hull/luma.oled. You can also watch this Hackster Project, which might help you with the LUMA OLED installation: https://www.hackster.io/gotfredsen/raspi-video-to-oled-a470e2.
Step 4: Modify Invaders.py Example
- The attached code is the complete code with modification. It is only been modified in the beginning with this code:
# Cap Touch modification Start import sys import smbus2 bus = smbus2.SMBus(1) DEVICE_ADDRESS = 0x28 CAP_TOUCH_GENERAL_STATUS = 0x02 CAP_TOUCH_SENSOR_INPUT_STATUS = 0x03 bus.write_byte_data(DEVICE_ADDRESS, 0x27, 0x0) bus.write_byte_data(DEVICE_ADDRESS, 0x21, 0x39) bus.write_byte_data(DEVICE_ADDRESS, 0x0, 0x0) # Cap Touch modification End
- And in the end with this code:
# Cap Touch Code Start
touch_type = bus.read_byte_data(DEVICE_ADDRESS,CAP_TOUCH_GENERAL_STATUS)
if touch_type == 0x01:
button = bus.read_byte_data(DEVICE_ADDRESS,CAP_TOUCH_SENSOR_INPUT_STATUS)
if button == 0x01:
sys.exit("User exit!")
if button == 0x20:
plyr.update(1)
if button == 0x08:
plyr.shoot()
plyr.update(0)
if button == 0x10:
plyr.update(-1)
# ai_logic_shoot(army, plyr)
# ai_logic_move(army, plyr, rows)
# Cap Touch Code End- Now run the code: ./invaders.py or python invaders.py
Step 5: Code
invaders.py Python
This is the code, originally from Richard Hull's LUMA examples:
#!/usr/bin/env python
# -*- coding: utf-8 -*-
# Copyright (c) 2014-17 Richard Hull and contributors
# See LICENSE.rst for details.
# PYTHON_ARGCOMPLETE_OK
# Cap Touch by XinaBox
Space Invaders demo.
Ported from:
https://gist.github.com/TheRayTracer/dd12c498e3ecb9b8b47f#file-invaders-py
import os.path
import time
import random
from demo_opts import get_device
from PIL import Image
from luma.core.render import canvas
from luma.core.sprite_system import framerate_regulator
import sys
import smbus2
DEVICE_ADDRESS = 0x28<br>CAP_TOUCH_GENERAL_STATUS = 0x02
arrow = [0x04, 0x02, 0x01, 0x02, 0x04]
alien1 = [0x4C, 0x1A, 0xB6, 0x5F, 0x5F, 0xB6, 0x1A, 0x4C]
alien2 = [0x18, 0xFD, 0xA6, 0x3C, 0x3C, 0xA6, 0xFD, 0x18]
alien3 = [0xFC, 0x98, 0x35, 0x7E, 0x7E, 0x35, 0x98, 0xFC]
ARMY_SIZE_ROWS = 2
ARMY_SIZE_COLS = 6
class bullet(object):
def __init__(self, x, y):
self.x = x
self.y = y
self.alive = False
def render(self, draw):
if self.alive:
draw.line((self.x, self.y, self.x, self.y + 2), fill="white")
def reset(self, x, y):
self.x = x
self.y = y
self.alive = True
return
def update(self, direction):
if self.alive:
self.y = self.y + (direction * 4)
if self.y < 10:
self.alive = False
class player(object):
def __init__(self):
self.x = 48
self.y = 54
self.bullets = [bullet(0, 0) for _ in range(4)]
for i in range(len(arrow)):
line = arrow[i]
for j in range(3):
if line & 0x1:
draw.point((self.x - 2 + i, self.y + j), fill="white")
line >>= 1
for bullet in self.bullets:
bullet.render(draw)
t = self.x + (direction * 2)
if t > 4 and t < 92:
self.x = t
bullet.update(-1)
def shoot(self):
if not bullet.alive:
bullet.reset(self.x, self.y)
break
class invader(object):
def __init__(self, minx, maxx, x, y):
self.x = x
self.y = y
self._direction = 1
self.alive = True
self.score = 10
self._minx = minx
self._maxx = maxx
return
if self.alive:
for i in range(len(alien2)):
line = alien2[i]
for j in range(8):
if line & 0x1:
draw.point((self.x - 4 + i, self.y - 4 + j), "green")
line >>= 1
def update(self):
invaded = False
if self.alive:
t = self.x + self._direction
if t > self._minx and t < self._maxx:
self.x = self.x + self._direction
else:
self._direction = self._direction * -1
self.y = self.y + 2
if self.y > 44:
invaded = True
return invaded
class army(object):
def __init__(self):
self.invaded = False
self.invaders = []
for i in range(ARMY_SIZE_ROWS):
for j in range(ARMY_SIZE_COLS):
minx = 4 + (j * 12)
maxx = 30 + (j * 12)
x = 4 + (j * 12)
y = 14 + (i * 12)
self.invaders.append(invader(minx, maxx, x, y))
for invader in self.invaders:
invader.render(draw)
def update(self, bullets):
if invader.update():
self.invaded = True
if invader.alive:
for bullet in bullets:
if bullet.alive:
t = (invader.x - bullet.x) * (invader.x - bullet.x) + (invader.y - bullet.y) * (invader.y - bullet.y)
# if point is in circle
if t < 25: # 5 * 5 = r * r
invader.alive = False
bullet.alive = False
def size(self):
size = 0
if invader.alive:
size += 1
return size
def score(self):
score = 0
if not invader.alive:
score += invader.score
return score
def ai_logic_shoot(army, plyr):
for invader in army.invaders:
if invader.alive:
if plyr.x > (invader.x - 2) and plyr.x < (invader.x + 2):
if random.random() < 0.75:
plyr.shoot()
return
def ai_logic_move(army, plyr, rows):
for i in rows:
invader = army.invaders[i]
if invader.alive:
if plyr.x < invader.x:
plyr.update(1)
return
elif plyr.x > invader.x:
plyr.update(-1)
return
i += 1
if __name__ == '__main__':
device = get_device()
if device.width < 96 or device.height < 64:
raise ValueError("Unsupported mode: {0}x{1}".format(device.width, device.height))
regulator = framerate_regulator()
plyr = player()
army = army()
rows = random.sample(range(12), 12)
img_path = os.path.abspath(os.path.join(os.path.dirname(__file__), 'images', 'splash.bmp'))
splash = Image.open(img_path) \
.transform((device.width, device.height), Image.AFFINE, (1, 0, 0, 0, 1, 0), Image.BILINEAR) \
.convert(device.mode)
try:
# Double buffering in pygame?
device.display(splash)
time.sleep(3)
device.clear()
while not army.invaded and army.size() > 0:
with regulator:
with canvas(device) as draw:
draw.line((0, 61, 95, 61), fill="white")
draw.line((0, 63, 95, 63), fill="white")
if button == 0x01:
if button == 0x20:
plyr.update(1)
if button == 0x08:
plyr.shoot()
plyr.update(0)
if button == 0x10:
plyr.update(-1)
army.update(plyr.bullets)
army.render(draw)
plyr.render(draw)
draw.text((8, 0), text="Score: {0}".format(army.score()), fill="blue")
for i in range(2):
if army.size() == 0:
draw.text((27, 28), text="Victory", fill="blue")
else:
draw.text((30, 28), text="Defeat", fill="red")
time.sleep(5)
except KeyboardInterrupt:
pass
