Introduction: Space Saving Hand Tool Storage
Storing screwdrivers and such with pegboard hooks was taking up too much space. So I got to thinking, what could I do to increase the number of tools stored in a relatively smaller space yet still readily accessible.
Scrap plywood. I used 3/4"
Two screws
Step 1: Measure and Cut Board
Measure your available space. I wanted to add this board across the top of my bench space. I cut two pieces of 3/4" plywood and glued them together. The more clamps the merrier.
Step 2: Locate and Drill Holes
I decided on two, offset rows of holes. With a scrap piece, I drilled a few holes to determine the required sizes. 1/4" is a good fit for most Phillips head screwdrivers, while 3/8" worked for the rest. I angled the board so my holes weren't perpendicular once the board was mounted.
Step 3: Mount Board and Load Tools
With the holes drilled there is nothing left to do but attach the board and load up your tools. I used a hole on each end to run a screw thru into the wall behind.
