Introduction: Space Trash Game Using Arduino and OLED Display
Dear friends,
Welcome to Pi BOTS MakerHub. Today we are going to make a Game using Arduino and OLED Display. I recommend using the 128x64 pixels OLED display with I2C or SPI Communication, and a smaller Arduino like PRO Mini. But I use Arduino UNO since Components are not available for purchase due to COVID19. We could make this game console using ATtiny85 also.
Hardware components
- Arduino UNO & Genuino UNO
(Or any other Arduino Compatible Microcontroller Like Attiny85 is enough.)
- OLED Display 128x64Both i2c and SPI will work.
- SparkFun Pushbutton switch 12mm
- Resistor 10k ohm
- General-purpose PCB or Breadboard.
- Female Header
- Male Header
- 4xAA battery holder
Software apps and online services
- Arduino IDE
Hand tools and fabrication machines
- Soldering iron (generic)
- Solder Wire
Step 1: Get All the Parts
The project is really simple and easy to build. The parts needed in order to build this project are the following:
- Arduino UNO or any other equivalent.
- Pushbutton
- 10k Ohm Resistor
- PCB or breadboard
- Male and Female Connectors or Jumper cables
- 4x AA Batteries and Holder
Step 2: Build the Prototype Circuit
The connection is very simple. The connection diagram is provided below.
Connecting the OLED Display
- Vcc of the display goes to the 5V output of the Arduino.
- GND of the display goes to the Arduino GND pin.
- SDA pin of the display goes to A4 or SDA pin of the Arduino.
- SCL pin of the display goes to A5 or SCL pin of the Arduino.
Connecting the Pushbuttons
- Up button to D3 of Arduino
- Down button to D4 of Arduino
- Fire button to D5 of Arduino
Step 3: Programming Arduino
Before we can program Arduino, we need to install U8G2 Library for OLED Display. The steps for installing the U8G2 libraryand uploading the code to the Arduino are shown in the below-attached images.
Step 4: Watch Our YouTube Video to Make Sure You Have Done It Correctly.
Step 5: Arduino Code
You can download the code and the circuit from below Link.
DOWNLOAD
SpaceTrash.ino
Universal 8bit Graphics Library (https://github.com/olikraus/u8g2/)
Copyright (c) 2016, olikraus@gmail.com
All rights reserved.
Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
* Redistributions of source code must retain the above copyright notice, this list
of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright notice, this
list of conditions and the following disclaimer in the documentation and/or other
materials provided with the distribution.
THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
CONTRIBUTORS "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES,
INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT,
STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include
#include
#ifdef U8X8_HAVE_HW_SPI
#include
#endif
#ifdef U8X8_HAVE_HW_I2C
#include
#endif
// Please UNCOMMENT one of the contructor lines below
// U8g2 Contructor List (Picture Loop Page Buffer)
// The complete list is available here: https://github.com/olikraus/u8g2/wiki/u8g2setupcpp
// Please update the pin numbers according to your setup. Use U8X8_PIN_NONE if the reset pin is not connected
//U8G2_NULL u8g2(U8G2_R0); // null device, a 8x8 pixel display which does nothing
//U8G2_SSD1306_128X64_NONAME_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 12, /* dc=*/ 4, /* reset=*/ 6); // Arduboy (Production, Kickstarter Edition)
//U8G2_SSD1306_128X64_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_3W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* reset=*/ 8);
U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_128X64_ALT0_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // same as the NONAME variant, but may solve the "every 2nd line skipped" problem
//U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); // All Boards without Reset of the Display
//U8G2_SSD1306_128X64_NONAME_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 16, /* data=*/ 17, /* reset=*/ U8X8_PIN_NONE); // ESP32 Thing, pure SW emulated I2C
//U8G2_SSD1306_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE, /* clock=*/ 16, /* data=*/ 17); // ESP32 Thing, HW I2C with pin remapping
//U8G2_SSD1306_128X64_NONAME_1_6800 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /*enable=*/ 7, /*cs=*/ 10, /*dc=*/ 9, /*reset=*/ 8);
//U8G2_SSD1306_128X64_NONAME_1_8080 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /*enable=*/ 7, /*cs=*/ 10, /*dc=*/ 9, /*reset=*/ 8);
//U8G2_SSD1306_128X64_VCOMH0_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // same as the NONAME variant, but maximizes setContrast() range
//U8G2_SSD1306_128X64_ALT0_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // same as the NONAME variant, but may solve the "every 2nd line skipped" problem
//U8G2_SH1106_128X64_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SH1106_128X64_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SH1106_128X64_VCOMH0_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // same as the NONAME variant, but maximizes setContrast() range
//U8G2_SH1106_128X64_WINSTAR_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // same as the NONAME variant, but uses updated SH1106 init sequence
//U8G2_SH1106_72X40_WISE_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SH1107_64X128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SH1107_128X128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SH1107_128X128_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8);
//U8G2_SH1107_PIMORONI_128X128_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8);
//U8G2_SH1107_SEEED_128X128_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SH1107_SEEED_128X128_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SH1107_SEEED_96X96_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SH1108_160X160_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SH1122_256X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SSD1306_128X32_UNIVISION_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 21, /* data=*/ 20, /* reset=*/ U8X8_PIN_NONE); // Adafruit Feather M0 Basic Proto + FeatherWing OLED
//U8G2_SSD1306_128X32_UNIVISION_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); // Adafruit Feather ESP8266/32u4 Boards + FeatherWing OLED
//U8G2_SSD1306_128X32_UNIVISION_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // Adafruit ESP8266/32u4/ARM Boards + FeatherWing OLED
//U8G2_SSD1306_128X32_UNIVISION_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE, /* clock=*/ SCL, /* data=*/ SDA); // pin remapping with ESP8266 HW I2C
//U8G2_SSD1306_128X32_WINSTAR_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE, /* clock=*/ SCL, /* data=*/ SDA); // pin remapping with ESP8266 HW I2C
//U8G2_SSD1306_64X48_ER_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // EastRising 0.66" OLED breakout board, Uno: A4=SDA, A5=SCL, 5V powered
//U8G2_SSD1306_48X64_WINSTAR_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_64X32_NONAME_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_64X32_1F_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1306_96X16_ER_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // EastRising 0.69" OLED
//U8G2_SSD1322_NHD_256X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SSD1322_NHD_256X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Enable U8G2_16BIT in u8g2.h
//U8G2_SSD1322_NHD_128X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1322_NHD_128X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1325_NHD_128X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1325_NHD_128X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD0323_OS128064_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD0323_OS128064_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1326_ER_256X32_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // experimental driver for ER-OLED018-1
//U8G2_SSD1327_SEEED_96X96_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ U8X8_PIN_NONE); // Seeedstudio Grove OLED 96x96
//U8G2_SSD1327_SEEED_96X96_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE); // Seeedstudio Grove OLED 96x96
//U8G2_SSD1327_EA_W128128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1327_EA_W128128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1327_EA_W128128_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ 5, /* data=*/ 4, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1327_EA_W128128_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_SSD1327_MIDAS_128X128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1327_MIDAS_128X128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1327_WS_128X128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1327_WS_128X128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1329_128X96_NONAME_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1329_128X96_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1305_128X32_NONAME_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1305_128X32_NONAME_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1305_128X32_ADAFRUIT_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1305_128X32_ADAFRUIT_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1305_128X64_ADAFRUIT_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1305_128X64_ADAFRUIT_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME0_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME0_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME2_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1309_128X64_NONAME2_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1316_128X32_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1316_128X32_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1317_96X96_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // not tested, not confirmed
//U8G2_SSD1317_96X96_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // not tested, not confirmed
//U8G2_SSD1318_128X96_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_SSD1318_128X96_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_LD7032_60X32_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 11, /* data=*/ 12, /* cs=*/ 9, /* dc=*/ 10, /* reset=*/ 8); // SW SPI Nano Board
//U8G2_LD7032_60X32_1_4W_SW_I2C u8g2(U8G2_R0, /* clock=*/ 11, /* data=*/ 12, /* reset=*/ U8X8_PIN_NONE); // NOT TESTED!
//U8G2_UC1701_EA_DOGS102_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_UC1701_EA_DOGS102_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_PCD8544_84X48_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Nokia 5110 Display
//U8G2_PCD8544_84X48_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Nokia 5110 Display
//U8G2_PCF8812_96X65_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Could be also PCF8814
//U8G2_PCF8812_96X65_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Could be also PCF8814
//U8G2_HX1230_96X68_1_3W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* reset=*/ 8);
//U8G2_HX1230_96X68_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_KS0108_128X64_1 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*dc=*/ 17, /*cs0=*/ 14, /*cs1=*/ 15, /*cs2=*/ U8X8_PIN_NONE, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//U8G2_KS0108_ERM19264_1 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*dc=*/ 17, /*cs0=*/ 14, /*cs1=*/ 15, /*cs2=*/ 16, /* reset=*/ U8X8_PIN_NONE); // Set R/W to low!
//U8G2_ST7920_192X32_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ U8X8_PIN_NONE, /*dc=*/ 17, /*reset=*/ U8X8_PIN_NONE);
//U8G2_ST7920_192X32_1_SW_SPI u8g2(U8G2_R0, /* clock=*/ 18 /* A4 */ , /* data=*/ 16 /* A2 */, /* CS=*/ 17 /* A3 */, /* reset=*/ U8X8_PIN_NONE);
//U8G2_ST7920_128X64_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18 /* A4 */, /*cs=*/ U8X8_PIN_NONE, /*dc/rs=*/ 17 /* A3 */, /*reset=*/ 15 /* A1 */); // Remember to set R/W to 0
//U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, /* clock=*/ 18 /* A4 */ , /* data=*/ 16 /* A2 */, /* CS=*/ 17 /* A3 */, /* reset=*/ U8X8_PIN_NONE);
//U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* CS=*/ 10, /* reset=*/ 8);
//U8G2_ST7920_128X64_1_SW_SPI u8g2(U8G2_R0, /* clock=*/ 14, /* data=*/ 13, /* CS=*/ 15, /* reset=*/ 16); // Feather HUZZAH ESP8266, E=clock=14, RW=data=13, RS=CS
//U8G2_ST7920_128X64_1_HW_SPI u8g2(U8G2_R0, /* CS=*/ 10, /* reset=*/ 8);
//U8G2_ST7920_128X64_1_HW_SPI u8g2(U8G2_R0, /* CS=*/ 15, /* reset=*/ 16); // Feather HUZZAH ESP8266, E=clock=14, RW=data=13, RS=CS
//U8G2_ST7565_EA_DOGM128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_EA_DOGM128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_64128N_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_64128N_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_EA_DOGM132_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ U8X8_PIN_NONE); // DOGM132 Shield
//U8G2_ST7565_EA_DOGM132_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ U8X8_PIN_NONE); // DOGM132 Shield
//U8G2_ST7565_ZOLEN_128X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_ZOLEN_128X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_LM6059_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Adafruit ST7565 GLCD
//U8G2_ST7565_LM6059_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Adafruit ST7565 GLCD
//U8G2_ST7565_LX12864_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_LX12864_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_ERC12864_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_ERC12864_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_ERC12864_ALT_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // contrast improved version for ERC12864
//U8G2_ST7565_ERC12864_ALT_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // contrast improved version for ERC12864
//U8G2_ST7565_NHD_C12832_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_NHD_C12832_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_NHD_C12864_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_NHD_C12864_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_JLX12864_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7565_JLX12864_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_PI_132X64_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 7, /* dc=*/ 9, /* reset=*/ 8); // Pax Instruments Shield, LCD_BL=6
//U8G2_ST7567_PI_132X64_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 7, /* dc=*/ 9, /* reset=*/ 8); // Pax Instruments Shield, LCD_BL=6
//U8G2_ST7567_JLX12864_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 7, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_JLX12864_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 7, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_ENH_DG128064_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_ENH_DG128064_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_ENH_DG128064I_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_ENH_DG128064I_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7567_64X32_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
//U8G2_ST75256_JLX172104_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST75256_JLX172104_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST75256_JLX19296_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST75256_JLX19296_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST75256_JLX256128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_WO256X128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_WO256X128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 9, /* data=*/ 8, /* cs=*/ 7, /* dc=*/ 6, /* reset=*/ 5); // MKR Zero, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 7, /* dc=*/ 6, /* reset=*/ 5); // MKR Zero, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160M_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160M_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_ALT_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX256160_ALT_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75256_JLX240160_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST75256_JLX240160_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST75256_JLX25664_1_2ND_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8); // Due, 2nd I2C, enable U8g2 16 bit mode for this display
//U8G2_ST75320_JLX320240_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_ST75320_JLX320240_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Uno, Enable U8g2 16 bit mode for this display
//U8G2_NT7534_TG12864R_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_NT7534_TG12864R_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_ST7588_JLX12864_1_SW_I2C u8g2(U8G2_R0, /* clock=*/ SCL, /* data=*/ SDA, /* reset=*/ 5);
//U8G2_ST7588_JLX12864_1_HW_I2C u8g2(U8G2_R0, /* reset=*/ 5);
//U8G2_IST3020_ERC19264_1_6800 u8g2(U8G2_R0, 44, 43, 42, 41, 40, 39, 38, 37, /*enable=*/ 28, /*cs=*/ 32, /*dc=*/ 30, /*reset=*/ 31); // Connect WR pin with GND
//U8G2_IST3020_ERC19264_1_8080 u8g2(U8G2_R0, 44, 43, 42, 41, 40, 39, 38, 37, /*enable=*/ 29, /*cs=*/ 32, /*dc=*/ 30, /*reset=*/ 31); // Connect RD pin with 3.3V
//U8G2_IST3020_ERC19264_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_LC7981_160X80_1_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RW with GND
//U8G2_LC7981_160X160_1_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RW with GND
//U8G2_LC7981_240X128_1_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RW with GND
//U8G2_LC7981_240X64_1_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RW with GND
//U8G2_SED1520_122X32_1 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*dc=*/ A0, /*e1=*/ A3, /*e2=*/ A2, /* reset=*/ A4); // Set R/W to low!
//U8G2_T6963_240X128_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable/wr=*/ 17, /*cs/ce=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_256X64_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable/wr=*/ 17, /*cs/ce=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_160X80_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable/wr=*/ 17, /*cs/ce=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_128X64_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable/wr=*/ 17, /*cs/ce=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_T6963_128X64_ALT_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable/wr=*/ 17, /*cs/ce=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect RD with +5V, FS0 and FS1 with GND
//U8G2_SED1330_240X128_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 17, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect /RD = E with +5V, enable is /WR = RW, FG with GND, 14=Uno Pin A0
//U8G2_SED1330_240X128_1_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 17, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // A0 is dc pin, /WR = RW = GND, enable is /RD = E
//U8G2_RA8835_NHD_240X128_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 17, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // Connect /RD = E with +5V, enable is /WR = RW, FG with GND, 14=Uno Pin A0
//U8G2_RA8835_NHD_240X128_1_6800 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 17, /*cs=*/ 14, /*dc=*/ 15, /*reset=*/ 16); // A0 is dc pin, /WR = RW = GND, enable is /RD = E
//U8G2_UC1601_128X32_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_UC1601_128X32_1_3W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* reset=*/ 8);
//U8G2_UC1604_JLX19264_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_UC1604_JLX19264_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_UC1608_ERC24064_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // SW SPI, Due ERC24064-1 Test Setup
//U8G2_UC1608_ERC240120_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8);
//U8G2_UC1608_240X128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // SW SPI, Due ERC24064-1 Test Setup
//U8G2_UC1610_EA_DOGXL160_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ U8X8_PIN_NONE);
//U8G2_UC1610_EA_DOGXL160_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ U8X8_PIN_NONE);
//U8G2_UC1611_EA_DOGM240_1_2ND_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8); // Due, 2nd I2C, DOGM240 Test Board
//U8G2_UC1611_EA_DOGM240_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // SW SPI, Due DOGXL240 Test Board
//U8G2_UC1611_EA_DOGXL240_1_2ND_HW_I2C u8g2(U8G2_R0, /* reset=*/ 8); // Due, 2nd I2C, DOGXL240 Test Board
//U8G2_UC1611_EA_DOGXL240_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // SW SPI, Due DOGXL240 Test Board
//U8G2_UC1611_EW50850_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ 3, /*dc=*/ 16, /*reset=*/ 17); // 240x160, Connect RD/WR1 pin with 3.3V, CS is aktive high
//U8G2_UC1611_CG160160_1_8080 u8g2(U8G2_R0, 8, 9, 10, 11, 4, 5, 6, 7, /*enable=*/ 18, /*cs=*/ 3, /*dc=*/ 16, /*reset=*/ 17); // Connect WR1 and CD1 pin with 3.3V, connect CS0 with cs, WR0 with enable, CD with dc
//U8G2_UC1638_160X128_1_4W_HW_SPI u8g2(U8G2_R2, /* cs=*/ 2, /* dc=*/ 3, /* reset=*/ 4); // Not tested
//U8G2_SSD1606_172X72_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // eInk/ePaper Display
//U8G2_SSD1607_200X200_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // eInk/ePaper Display, original LUT from embedded artists
//U8G2_SSD1607_GD_200X200_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Good Display
//U8G2_SSD1607_WS_200X200_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // Waveshare
//U8G2_IL3820_296X128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // WaveShare 2.9 inch eInk/ePaper Display, enable 16 bit mode for this display!
//U8G2_IL3820_V2_296X128_1_4W_SW_SPI u8g2(U8G2_R0, /* clock=*/ 13, /* data=*/ 11, /* cs=*/ 10, /* dc=*/ 9, /* reset=*/ 8); // ePaper Display, lesser flickering and faster speed, enable 16 bit mode for this display!
//U8G2_LS013B7DH03_128X128_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ U8X8_PIN_NONE, /* reset=*/ 8); // there is no DC line for this display
//U8G2_LS027B7DH01_400X240_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ U8X8_PIN_NONE, /* reset=*/ 8); // there is no DC line for this display
//U8G2_LS013B7DH05_144X168_1_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ 10, /* dc=*/ U8X8_PIN_NONE, /* reset=*/ 8); // there is no DC line for this display
//U8G2_ST7511_AVD_320X240_1_8080 u8g2(U8G2_R0, 13, 11, 2, 3, 4, 5, 6, A4, /*enable/WR=*/ 7, /*cs=*/ 10, /*dc=*/ 9, /*reset=*/ 8); // Enable U8g2 16Bit Mode and connect RD pin with 3.3V/5V
// End of constructor list
/* button setup for Arduboy Production */
uint8_t pin_up = 3;
uint8_t pin_down = 4;
uint8_t pin_fire = 5;
#define ST_FP 4
/* object types */
struct _st_ot_struct
missle and hit:
bit 0: player missle and trash
bit 1: trash, which might hit the player
uint8_t missle_mask; /* this object is a missle: it might destroy something if the target is_hit_fn says so */
uint8_t hit_mask; /* if missle_mask & hit_mask is != 0 then the object can be destroyed */
uint8_t points;
uint8_t draw_fn;
uint8_t move_fn;
/* ST_MOVE_FN_NONE, ST_MOVE_FN_X_SLOW */
uint8_t destroy_fn; /* object can be destroyed by a missle (e.g. a missle from the space ship) */
/* ST_DESTROY_FN_NONE, ST_DESTROY_FN_SPLIT */
uint8_t is_hit_fn; /* is hit procedure */
/* ST_IS_HIT_FN_NONE, ST_IS_HIT_BBOX */
uint8_t fire_fn;
/* ST_FIRE_FN_NONE, ST_FIRE_FN_X_LEFT */
typedef struct _st_ot_struct st_ot;
objects, which are visible at the play area
struct _st_obj_struct
uint8_t ot; /* object type: zero means, object is not used */
int8_t tmp; /* generic value, used by ST_MOVE_IMPLODE */
/* absolute position */
/* LCD pixel position is x>>ST_FP and y>>ST_FP */
int16_t x, y;
int8_t x0,y0,x1,y1; /* object outline in pixel, reference point is at 0,0 */
typedef struct _st_obj_struct st_obj;
#define ST_DRAW_NONE 0
#define ST_DRAW_BBOX 1
#define ST_DRAW_TRASH1 2
#define ST_DRAW_PLAYER1 3
#define ST_DRAW_TRASH2 4
#define ST_DRAW_PLAYER2 5
#define ST_DRAW_PLAYER3 6
#define ST_DRAW_GADGET 7
#define ST_DRAW_BACKSLASH 8
#define ST_DRAW_SLASH 9
#define ST_DRAW_BIG_TRASH 10
#define ST_MOVE_NONE 0
#define ST_MOVE_X_SLOW 1
#define ST_MOVE_PX_NORMAL 2
#define ST_MOVE_PX_FAST 3
#define ST_MOVE_PLAYER 4
#define ST_MOVE_PY 5
#define ST_MOVE_NY 6
#define ST_MOVE_IMPLODE 7
#define ST_MOVE_X_FAST 8
#define ST_MOVE_WALL 9
#define ST_MOVE_NXPY 10
#define ST_MOVE_NXNY 11
#define ST_IS_HIT_NONE 0
#define ST_IS_HIT_BBOX 1
#define ST_IS_HIT_WALL 2
#define ST_DESTROY_NONE 0
#define ST_DESTROY_DISAPPEAR 1
#define ST_DESTROY_TO_DUST 2
#define ST_DESTROY_GADGET 3
#define ST_DESTROY_PLAYER 4
#define ST_DESTROY_PLAYER_GADGETS 5
#define ST_DESTROY_BIG_TRASH 6
#define ST_FIRE_NONE 0
#define ST_FIRE_PLAYER1 1
#define ST_FIRE_PLAYER2 2
#define ST_FIRE_PLAYER3 3
#define ST_OT_WALL_SOLID 1
#define ST_OT_BIG_TRASH 2
#define ST_OT_MISSLE 3
#define ST_OT_TRASH1 4
#define ST_OT_PLAYER 5
#define ST_OT_DUST_PY 6
#define ST_OT_DUST_NY 7
#define ST_OT_TRASH_IMPLODE 8
#define ST_OT_TRASH2 9
#define ST_OT_PLAYER2 10
#define ST_OT_PLAYER3 11
#define ST_OT_GADGET 12
#define ST_OT_GADGET_IMPLODE 13
#define ST_OT_DUST_NXPY 14
#define ST_OT_DUST_NXNY 15
/* graphics object */
u8g2_t *st_u8g2;
u8g2_uint_t u8g_height_minus_one;
#define ST_AREA_HEIGHT (st_u8g2->height - 8)
#define ST_AREA_WIDTH (st_u8g2->width)
/* object types */
const st_ot st_object_types[] U8X8_PROGMEM =
/* 0: empty object type */
{ 0, 0, 0, ST_DRAW_NONE, ST_MOVE_NONE, ST_DESTROY_DISAPPEAR, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* 1: wall, player will be destroyed */
{ 2, 1, 30, ST_DRAW_BBOX, ST_MOVE_WALL, ST_DESTROY_DISAPPEAR, ST_IS_HIT_WALL, ST_FIRE_NONE },
/* ST_OT_BIG_TRASH (2) */
{ 2, 1, 0, ST_DRAW_BIG_TRASH, ST_MOVE_X_SLOW, ST_DESTROY_BIG_TRASH, ST_IS_HIT_BBOX, ST_FIRE_NONE },
/* 3: simple space ship (player) missle */
{ 1, 0, 0, ST_DRAW_BBOX, ST_MOVE_PX_FAST, ST_DESTROY_DISAPPEAR, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* ST_OT_TRASH1 (4): trash */
{ 2, 1, 0, ST_DRAW_TRASH1, ST_MOVE_X_SLOW, ST_DESTROY_TO_DUST, ST_IS_HIT_BBOX, ST_FIRE_NONE },
/* ST_OT_PLAYER (5): player space ship */
{ 0, 2, 0, ST_DRAW_PLAYER1, ST_MOVE_PLAYER, ST_DESTROY_PLAYER, ST_IS_HIT_BBOX, ST_FIRE_PLAYER1 },
/* ST_OT_DUST_PY (6): Last part of trash */
{ 0, 0, 0, ST_DRAW_BBOX, ST_MOVE_PY, ST_DESTROY_NONE, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* ST_OT_DUST_NY (7): Last part of trash */
{ 0, 0, 0, ST_DRAW_BBOX, ST_MOVE_NY, ST_DESTROY_NONE, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* ST_OT_TRASH_IMPLODE (8): trash was hit */
{ 0, 0, 5, ST_DRAW_TRASH1, ST_MOVE_IMPLODE, ST_DESTROY_NONE, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* ST_OT_TRASH2 (9): trash */
{ 2, 1, 0, ST_DRAW_TRASH2, ST_MOVE_X_SLOW, ST_DESTROY_TO_DUST, ST_IS_HIT_BBOX, ST_FIRE_NONE },
/* ST_OT_PLAYER2 (10): player space ship+1x enhancement */
{ 0, 2, 0, ST_DRAW_PLAYER2, ST_MOVE_PLAYER, ST_DESTROY_PLAYER_GADGETS, ST_IS_HIT_BBOX, ST_FIRE_PLAYER2 },
/* ST_OT_PLAYER3 (11): player space ship+2x enhancement */
{ 0, 2, 0, ST_DRAW_PLAYER3, ST_MOVE_PLAYER, ST_DESTROY_PLAYER_GADGETS, ST_IS_HIT_BBOX, ST_FIRE_PLAYER3 },
/* ST_OT_GADGET (12): adds enhancements */
{ 0, 1, 0, ST_DRAW_GADGET, ST_MOVE_X_FAST, ST_DESTROY_GADGET, ST_IS_HIT_BBOX, ST_FIRE_NONE },
/* ST_OT_GADGET_IMPLODE (13) */
{ 0, 0, 20, ST_DRAW_GADGET, ST_MOVE_IMPLODE, ST_DESTROY_NONE, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* ST_OT_DUST_NXPY (14): Last part of trash */
{ 0, 0, 0, ST_DRAW_BACKSLASH, ST_MOVE_NXPY, ST_DESTROY_NONE, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* ST_OT_DUST_NXNY (15): Last part of trash */
{ 0, 0, 0, ST_DRAW_SLASH, ST_MOVE_NXNY, ST_DESTROY_NONE, ST_IS_HIT_NONE, ST_FIRE_NONE },
/* list of all objects on the screen */
/* use AVR RAMEND constant to derive the number of allowed objects */
#if RAMEND < 0x300
#define ST_OBJ_CNT 25
#else
//#define ST_OBJ_CNT 45
#define ST_OBJ_CNT 60
#endif
st_obj st_objects[ST_OBJ_CNT];
/* about players space ship*/
/* player position */
uint8_t st_player_pos;
/* points */
#define ST_POINTS_PER_LEVEL 25
uint16_t st_player_points;
uint16_t st_player_points_delayed;
uint16_t st_highscore = 0;
/* overall game state */
#define ST_STATE_PREPARE 0
#define ST_STATE_IPREPARE 1
#define ST_STATE_GAME 2
#define ST_STATE_END 3
#define ST_STATE_IEND 4
uint8_t st_state = ST_STATE_PREPARE;
/* game difficulty */
uint8_t st_difficulty = 1;
#define ST_DIFF_VIS_LEN 30
#define ST_DIFF_FP 5
uint16_t st_to_diff_cnt = 0;
/* bitmaps */
const uint8_t st_bitmap_player1[] =
/* 01100000 */ 0x060,
/* 11111000 */ 0x0f8,
/* 01111110 */ 0x07e,
const uint8_t st_bitmap_player2[] =
/* 01111100 */ 0x078,
/* 11100000 */ 0x0e0,
const uint8_t st_bitmap_player3[] =
const uint8_t st_bitmap_trash_5x5_1[] =
/* 01110000 */ 0x070,
/* 11110000 */ 0x0f0,
/* 01111000 */ 0x078,
/* 00110000 */ 0x030,
const uint8_t st_bitmap_trash_5x5_2[] =
const uint8_t st_bitmap_trash_7x7[] =
/* 00111000 */ 0x038,
/* 01111100 */ 0x07c,
/* 11111100 */ 0x0fc,
/* 11111110 */ 0x0fe,
const uint8_t st_bitmap_gadget[] =
/* 11011000 */ 0x0d8,
/* 10001000 */ 0x088,
/* forward definitions */
uint8_t st_rnd(void) U8X8_NOINLINE;
static st_obj *st_GetObj(uint8_t objnr) U8X8_NOINLINE;
uint8_t st_GetMissleMask(uint8_t objnr);
uint8_t st_GetHitMask(uint8_t objnr);
int8_t st_FindObj(uint8_t ot) U8X8_NOINLINE;
void st_ClrObjs(void) U8X8_NOINLINE;
int8_t st_NewObj(void) U8X8_NOINLINE;
uint8_t st_CntObj(uint8_t ot);
uint8_t st_CalcXY(st_obj *o) U8X8_NOINLINE;
void st_SetXY(st_obj *o, uint8_t x, uint8_t y) U8X8_NOINLINE;
void st_FireStep(uint8_t is_auto_fire, uint8_t is_fire) U8X8_NOINLINE;
void st_InitTrash(uint8_t x, uint8_t y, int8_t dir);
void st_NewGadget(uint8_t x, uint8_t y);
void st_NewPlayerMissle(uint8_t x, uint8_t y) ;
void st_NewTrashDust(uint8_t x, uint8_t y, int ot);
void st_NewTrashDustAreaArgs(int16_t x, int16_t y, int ot);
void st_SetupPlayer(uint8_t objnr, uint8_t ot);
/* utility functions */
char st_itoa_buf[12];
char *st_itoa(unsigned long v)
volatile unsigned char i = 11;
st_itoa_buf[11] = '\0';
while( i > 0)
i--;
st_itoa_buf[i] = (v % 10)+'0';
v /= 10;
if ( v == 0 )
break;
return st_itoa_buf+i;
return rand();
for the specified index number, return the object
return st_objects+objnr;
check, if this is a missle-like object (that is, can this object destroy something else)
st_obj *o = st_GetObj(objnr);
return u8x8_pgm_read(&(st_object_types[o->ot].missle_mask));
return u8x8_pgm_read(&(st_object_types[o->ot].hit_mask));
search an empty object
int8_t i;
for( i = 0; i < ST_OBJ_CNT; i++ )
if ( st_objects[i].ot == ot )
return i;
return -1;
delete all objects
int8_t i;
st_objects[i].ot = 0;
int8_t i;
if ( st_objects[i].ot == 0 )
return i;
return -1;
count number of objectes of the provided type
st_CntObj(0) will return the number of empty objects, that means if
st_CntObj(0) > 0 then st_NewObj() will return a valid index
uint8_t i;
uint8_t cnt = 0;
cnt++;
return cnt;
calculate the pixel coordinates of the reference point of an object
return rhe x value
uint8_t st_px_x, st_px_y; /* pixel within area */
//st_obj *o = st_GetObj(objnr);
st_px_y = o->y>>ST_FP;
st_px_x = o->x>>ST_FP;
return st_px_x;
o->x = ((int16_t)x) << ST_FP;
o->y = ((int16_t)y) << ST_FP;
calculate the object bounding box and place it into some global variables
int16_t st_bbox_x0, st_bbox_y0, st_bbox_x1, st_bbox_y1;
void st_CalcBBOX(uint8_t objnr)
st_bbox_x0 = (uint16_t)(o->x>>ST_FP);
st_bbox_x1 = st_bbox_x0;
st_bbox_x0 += o->x0;
st_bbox_x1 += o->x1;
st_bbox_y0 = (uint16_t)(o->y>>ST_FP);
st_bbox_y1 = st_bbox_y0;
st_bbox_y0 += o->y0;
st_bbox_y1 += o->y1;
clip bbox with the view window. requires a call to st_CalcBBOX
return 0, if the bbox is totally outside the window
uint8_t st_cbbox_x0, st_cbbox_y0, st_cbbox_x1, st_cbbox_y1;
uint8_t st_ClipBBOX(void)
if ( st_bbox_x0 >= ST_AREA_WIDTH )
return 0;
if ( st_bbox_x0 >= 0 )
st_cbbox_x0 = (uint16_t)st_bbox_x0;
else
st_cbbox_x0 = 0;
if ( st_bbox_x1 < 0 )
return 0;
if ( st_bbox_x1 < ST_AREA_WIDTH )
st_cbbox_x1 = (uint16_t)st_bbox_x1;
else
st_cbbox_x1 = ST_AREA_WIDTH-1;
if ( st_bbox_y0 >= ST_AREA_HEIGHT )
return 0;
if ( st_bbox_y0 >= 0 )
st_cbbox_y0 = (uint16_t)st_bbox_y0;
else
st_cbbox_y0 = 0;
if ( st_bbox_y1 < 0 )
return 0;
if ( st_bbox_y1 < ST_AREA_HEIGHT )
st_cbbox_y1 = (uint16_t)st_bbox_y1;
else
st_cbbox_y1 = ST_AREA_HEIGHT-1;
return 1;
/* universal member functions */
uint8_t st_IsOut(uint8_t objnr)
st_CalcBBOX(objnr);
return 1;
return 1;
return 1;
return 1;
return 0;
void st_Disappear(uint8_t objnr)
st_player_points += u8x8_pgm_read(&(st_object_types[o->ot].points));
o->ot = 0;
/* type dependent member functions */
void st_Move(uint8_t objnr)
switch(u8x8_pgm_read(&(st_object_types[o->ot].move_fn)))
case ST_MOVE_NONE:
break;
case ST_MOVE_X_SLOW:
o->x -= (1<x -= st_difficulty;
o->y += (int16_t)o->tmp;
if ( o->y >= ((ST_AREA_HEIGHT-1) << ST_FP) || o->y <= 0 )
o->tmp = - o->tmp;
break;
case ST_MOVE_X_FAST:
o->x -= (1<y += (int16_t)o->tmp;
o->tmp = - o->tmp;
break;
case ST_MOVE_PX_NORMAL:
o->x += (1<x += (1<y = st_player_pos<y += 3*ST_FP;
break;
case ST_MOVE_NY:
o->y -= 3*ST_FP;
break;
case ST_MOVE_NXPY:
o->y += 3*ST_FP;
o->x -= 3*ST_FP;
break;
case ST_MOVE_NXNY:
o->y -= 3*ST_FP;
o->x -= 3*ST_FP;
break;
case ST_MOVE_IMPLODE:
o->tmp++;
if ( (o->tmp & 0x03) == 0 )
if ( o->x0 != o->x1 )
o->x0++;
else
st_Disappear(objnr);
break;
case ST_MOVE_WALL:
o->x -= 1;
o->x -= (st_difficulty>>1);
break;
void st_DrawBBOX(uint8_t objnr)
uint8_t y0, y1;
/*st_obj *o = st_GetObj(objnr);*/
st_CalcBBOX(objnr);
if ( st_ClipBBOX() == 0 )
return;
/* st_cbbox_x0, st_cbbox_y0, st_cbbox_x1, st_cbbox_y1; */
// w = st_cbbox_x1-st_cbbox_x0;
// w++;
// h = st_cbbox_y1-st_cbbox_y0;
// h++;
//dog_SetVLine(st_cbbox_x0, st_cbbox_y0, st_cbbox_y1);
//dog_SetVLine(st_cbbox_x1, st_cbbox_y0, st_cbbox_y1);
//dog_SetHLine(st_cbbox_x0, st_cbbox_x1, st_cbbox_y0);
//dog_SetHLine(st_cbbox_x0, st_cbbox_x1, st_cbbox_y1);
u8g2_SetDrawColor(st_u8g2, 1);
y0 = u8g_height_minus_one - st_cbbox_y0;
y1 = u8g_height_minus_one - st_cbbox_y1;
u8g2_DrawFrame(st_u8g2, st_cbbox_x0, y1, st_cbbox_x1-st_cbbox_x0+1, y0-y1+1);
//dog_SetBox(st_cbbox_x0, st_cbbox_y0, st_cbbox_x1, st_cbbox_y1);
if ( o->ot == ST_OT_PLAYER )
dog_DrawStr(0, 26, font_4x6, st_itoa(st_cbbox_y0));
dog_DrawStr(10, 26, font_4x6, st_itoa(st_cbbox_y1));
#ifdef FN_IS_NOT_IN_USE
void st_DrawFilledBox(uint8_t objnr)
st_CalcBBOX(objnr);
return;
#endif
void st_DrawBitmap(uint8_t objnr, const uint8_t * bm, uint8_t w, uint8_t h)
/* st_obj *o = st_GetObj(objnr); */
st_CalcBBOX(objnr);
/* result is here: int16_t st_bbox_x0, st_bbox_y0, st_bbox_x1, st_bbox_y1 */
//dog_SetBitmapP(st_bbox_x0,st_bbox_y1,bm,w,h);
u8g2_DrawBitmap(st_u8g2, st_bbox_x0, u8g_height_minus_one - st_bbox_y1, (w+7)/8, h, bm);
void st_DrawObj(uint8_t objnr)
switch(u8x8_pgm_read(&(st_object_types[o->ot].draw_fn)))
case ST_DRAW_NONE:
break;
case ST_DRAW_BBOX:
st_DrawBBOX(objnr);
break;
case ST_DRAW_TRASH1:
st_DrawBitmap(objnr, st_bitmap_trash_5x5_1,o->x1-o->x0+1, 5);
break;
case ST_DRAW_TRASH2:
st_DrawBitmap(objnr, st_bitmap_trash_5x5_2,o->x1-o->x0+1, 5);
break;
case ST_DRAW_BIG_TRASH:
st_DrawBitmap(objnr, st_bitmap_trash_7x7,o->x1-o->x0+1, 7);
break;
case ST_DRAW_PLAYER1:
st_DrawBitmap(objnr, st_bitmap_player1,7,5);
break;
case ST_DRAW_PLAYER2:
st_DrawBitmap(objnr, st_bitmap_player2,7,8);
break;
case ST_DRAW_PLAYER3:
st_DrawBitmap(objnr, st_bitmap_player3,7,11);
break;
case ST_DRAW_GADGET:
/* could use this proc, but... */
/* st_DrawBitmap(objnr, st_bitmap_gadget,o->x1-o->x0+1, 5); */
/* ... this one looks also funny. */
st_DrawBitmap(objnr, st_bitmap_gadget,5,5);
break;
case ST_DRAW_BACKSLASH:
uint8_t x;
uint8_t y;
x = st_CalcXY(o);
y = st_px_y;
// dog_SetPixel(x,y);
// x++; y--;
// x++; y--;
u8g2_DrawPixel(st_u8g2, x, u8g_height_minus_one - y);
x++; y--;
x++; y--;
break;
case ST_DRAW_SLASH:
uint8_t x;
uint8_t y;
x = st_CalcXY(o);
y = st_px_y;
// x++; y++;
// x++; y++;
x++; y++;
x++; y++;
break;
uint8_t st_IsHitBBOX(uint8_t objnr, uint8_t x, uint8_t y)
st_CalcBBOX(objnr);
return 0; /* obj is outside (not visible) */
if ( x < st_cbbox_x0 )
return 0;
if ( x > st_cbbox_x1 )
return 0;
if ( y < st_cbbox_y0 )
return 0;
if ( y > st_cbbox_y1 )
return 0;
return 1;
void st_Destroy(uint8_t objnr)
int8_t nr;
switch(u8x8_pgm_read(&(st_object_types[o->ot].destroy_fn)))
case ST_DESTROY_NONE: /* only usefull for missels or walls which stay alife */
break;
case ST_DESTROY_DISAPPEAR: /* this should be the default operation */
break;
case ST_DESTROY_GADGET:
nr = st_FindObj(ST_OT_PLAYER2);
if ( nr >= 0 )
st_SetupPlayer(nr, ST_OT_PLAYER3);
else
nr = st_FindObj(ST_OT_PLAYER);
if ( nr >= 0 )
st_SetupPlayer(nr, ST_OT_PLAYER2);
st_NewTrashDustAreaArgs(o->x, o->y, ST_OT_DUST_PY);
st_NewTrashDustAreaArgs(o->x, o->y, ST_OT_DUST_NY);
o->ot = ST_OT_GADGET_IMPLODE;
o->tmp = 0;
break;
case ST_DESTROY_TO_DUST:
o->ot = ST_OT_TRASH_IMPLODE;
o->tmp = 0;
break;
case ST_DESTROY_BIG_TRASH:
st_InitTrash((o->x>>ST_FP)-1, (o->y>>ST_FP)+3, 2+(st_rnd()&3));
st_InitTrash((o->x>>ST_FP)-2, (o->y>>ST_FP)-3, -2-(st_rnd()&3));
break;
case ST_DESTROY_PLAYER:
st_state = ST_STATE_END;
o->tmp = 0;
break;
case ST_DESTROY_PLAYER_GADGETS:
/* o->ot = ST_OT_PLAYER; */
st_SetupPlayer(objnr, ST_OT_PLAYER);
break;
check if the target (objnr) has been hit.
st_IsHit() must also destroy the target.
return value:
0: do not destroy the missle
1: destroy the missle
uint8_t st_IsHit(uint8_t objnr, uint8_t x, uint8_t y, uint8_t missle_mask)
uint8_t hit_mask = st_GetHitMask(objnr);
st_obj *o;
if ( (hit_mask & missle_mask) == 0 )
return 0;
switch(u8x8_pgm_read(&(st_object_types[o->ot].is_hit_fn)))
case ST_IS_HIT_NONE:
break;
case ST_IS_HIT_BBOX:
if ( st_IsHitBBOX(objnr, x, y) != 0 )
st_Destroy(objnr);
return 1;
break;
case ST_IS_HIT_WALL:
o->x0++;
if ( o->x0 < o->x1 )
st_NewTrashDust(x, y, ST_OT_DUST_NXPY);
st_NewTrashDust(x, y, ST_OT_DUST_NXNY);
else
st_Destroy(objnr);
st_NewTrashDust(x, y, ST_OT_DUST_NY);
st_NewTrashDust(x, y, ST_OT_DUST_PY);
return 1;
break;
return 0;
/* update all fire counters */
uint8_t st_fire_player = 0;
uint8_t st_fire_period = 51;
uint8_t st_manual_fire_delay = 20;
uint8_t st_is_fire_last_value = 0;
is_auto_fire == 1
is_fire will be ignored, autofire enabled
is_auto_fire == 0
a transition from 1 to 0 on the is_fire variable will issue a missle
if ( is_auto_fire != 0 )
st_fire_player++;
if ( st_fire_player >= st_fire_period )
st_fire_player = 0;
else
if ( st_fire_player < st_manual_fire_delay )
st_fire_player++;
else
if ( st_is_fire_last_value == 0 )
if ( is_fire != 0 )
st_fire_player = 0;
st_is_fire_last_value = is_fire;
void st_Fire(uint8_t objnr)
uint8_t x;
uint8_t y;
switch(u8x8_pgm_read(&(st_object_types[o->ot].fire_fn)))
case ST_FIRE_NONE:
break;
case ST_FIRE_PLAYER1:
if ( st_fire_player == 0 )
/* create missle at st_px_x and st_px_y */
x = st_CalcXY(o);
y = st_px_y;
st_NewPlayerMissle(x , y );
break;
case ST_FIRE_PLAYER2:
x = st_CalcXY(o);
y = st_px_y;
st_NewPlayerMissle(x , y+4 );
break;
case ST_FIRE_PLAYER3:
x = st_CalcXY(o);
y = st_px_y;
st_NewPlayerMissle(x , y-4 );
break;
/* object init functions */
x,y are pixel coordinats within the play arey
st_obj *o;
int8_t objnr = st_NewObj();
if ( objnr < 0 )
return;
st_SetXY(o, x, y);
o->ot = ST_OT_GADGET;
o->tmp = 8;
//o->x = (x)<y = (y)<x0 = -3;
o->x1 = 1;
o->y0 = -2;
o->y1 = 2;
dir: direction
0: random
!= 0 --> assigned
st_obj *o;
if ( objnr < 0 )
return;
if ( (st_rnd() & 1) == 0 )
o->ot = ST_OT_TRASH1;
else
o->ot = ST_OT_TRASH2;
if ( dir == 0 )
o->tmp = 0;
if ( st_rnd() & 1 )
if ( st_rnd() & 1 )
o->tmp++;
else
o->tmp--;
else
o->tmp = dir;
st_SetXY(o, x, y);
o->x1 = 1;
o->y0 = -2;
o->y1 = 2;
if ( st_difficulty >= 5 )
if ( (st_rnd() & 3) == 0 )
o->ot = ST_OT_BIG_TRASH;
o->y0--;
o->y1++;
o->x0--;
o->x1++;
st_obj *o;
if ( objnr < 0 )
return;
o->ot = ot;
st_SetXY(o, x, y);
//o->x = (x)<y = (y)<x0 = 0;
o->x1 = 0;
o->y0 = -2;
o->y1 = 2;
st_NewTrashDust(x>>ST_FP, y>>ST_FP, ot);
void st_NewWall(void)
st_obj *o;
int8_t h;
if ( objnr < 0 )
return;
o->ot = ST_OT_WALL_SOLID;
h = st_rnd();
h &= 63;
h = (int8_t)(((int16_t)h*(int16_t)(ST_AREA_HEIGHT/4))>>6);
h += ST_AREA_HEIGHT/6;
o->x0 = 0;
o->x1 = 5;
o->x = (ST_AREA_WIDTH-1)<y = (ST_AREA_HEIGHT-1)<y0 = -h;
o->y1 = 0;
else
o->y = (0)<y0 = 0;
o->y1 = h;
st_obj *o;
if ( objnr < 0 )
return;
o->ot = ST_OT_MISSLE;
st_SetXY(o, x, y);
//o->x = x<y = y<x0 = -4;
o->x1 = 1;
o->y0 = 0;
o->y1 = 0;
switch(ot)
case ST_OT_PLAYER:
o->ot = ot;
o->y0 = -2;
o->y1 = 2;
break;
case ST_OT_PLAYER2:
o->ot = ot;
o->y0 = -2;
o->y1 = 5;
break;
case ST_OT_PLAYER3:
o->ot = ot;
o->y0 = -5;
o->y1 = 5;
break;
void st_NewPlayer(void)
st_obj *o;
if ( objnr < 0 )
return;
o->x = 6<y = (ST_AREA_HEIGHT/2)<x0 = -6;
o->x1 = 0;
/* trash creation */
void st_InitDeltaWall(void)
uint8_t i;
uint8_t cnt = 0;
uint8_t max_x = 0;
uint8_t max_l;
uint8_t min_dist_for_new = 40;
uint8_t my_difficulty = st_difficulty;
if ( st_difficulty >= 2 )
max_l = ST_AREA_WIDTH;
max_l -= min_dist_for_new;
if ( my_difficulty > 30 )
my_difficulty = 30;
min_dist_for_new -= my_difficulty;
if ( st_objects[i].ot == ST_OT_WALL_SOLID )
cnt++;
if ( max_x < (st_objects[i].x>>ST_FP) )
max_x = (st_objects[i].x>>ST_FP);
/* if ( cnt < upper_trash_limit ) */
if ( max_x < max_l )
st_NewWall();
void st_InitDeltaTrash(void)
uint8_t i;
uint8_t cnt = 0;
uint8_t max_x = 0;
uint8_t max_l;
uint8_t upper_trash_limit = ST_OBJ_CNT-7;
uint8_t min_dist_for_new = 20;
if ( my_difficulty > 14 )
my_difficulty = 14;
if ( st_objects[i].ot == ST_OT_TRASH1 || st_objects[i].ot == ST_OT_TRASH2 || st_objects[i].ot == ST_OT_GADGET || st_objects[i].ot == ST_OT_BIG_TRASH )
cnt++;
if ( (st_difficulty >= 3) && ((st_rnd() & 7) == 0) )
st_NewGadget(ST_AREA_WIDTH-1, rand() & (ST_AREA_HEIGHT-1));
else
st_InitTrash(ST_AREA_WIDTH-1, rand() & (ST_AREA_HEIGHT-1),0 );
void st_InitDelta(void)
st_InitDeltaTrash();
st_InitDeltaWall();
uint8_t cnt;
cnt = st_CntObj(2);
if ( cnt == 0 )
st_InitBrick1();
/* API: game draw procedure */
void st_DrawInGame(uint8_t fps)
uint8_t i;
/* draw all objects */
st_DrawObj(i);
//dog_ClrBox(0, ST_AREA_HEIGHT, st_u8g2->width-1, ST_AREA_HEIGHT+3);
u8g2_SetDrawColor(st_u8g2, 0);
u8g2_DrawBox(st_u8g2, 0, u8g_height_minus_one - ST_AREA_HEIGHT-3, st_u8g2->width, 4);
u8g2_DrawHLine(st_u8g2, 0, u8g_height_minus_one - ST_AREA_HEIGHT+1, ST_AREA_WIDTH);
u8g2_DrawHLine(st_u8g2, 0, u8g_height_minus_one, ST_AREA_WIDTH);
u8g2_SetFont(st_u8g2, u8g_font_4x6r);
u8g2_DrawStr(st_u8g2, 0, u8g_height_minus_one - ST_AREA_HEIGHT, st_itoa(st_difficulty));
u8g2_DrawHLine(st_u8g2, 10, u8g_height_minus_one - ST_AREA_HEIGHT-3, (st_to_diff_cnt>>ST_DIFF_FP)+1);
u8g2_DrawVLine(st_u8g2, 10, u8g_height_minus_one - ST_AREA_HEIGHT-4, 3);
u8g2_DrawVLine(st_u8g2, 10+ST_DIFF_VIS_LEN, u8g_height_minus_one - ST_AREA_HEIGHT-4, 3);
/* player points */
u8g2_DrawStr(st_u8g2, ST_AREA_WIDTH-5*4-2, u8g_height_minus_one - ST_AREA_HEIGHT, st_itoa(st_player_points_delayed));
/* FPS output */
if ( fps > 0 )
//i = dog_DrawStr(ST_AREA_WIDTH-5*4-2-7*4, ST_AREA_HEIGHT, font_4x6, "FPS:");
i = u8g2_DrawStr(st_u8g2, ST_AREA_WIDTH-5*4-2-7*4, u8g_height_minus_one - ST_AREA_HEIGHT, "FPS:");
//dog_DrawStr(ST_AREA_WIDTH-5*4-2-7*4+i, ST_AREA_HEIGHT, font_4x6, st_itoa(fps));
u8g2_DrawStr(st_u8g2, ST_AREA_WIDTH-5*4-2-7*4+i, u8g_height_minus_one - ST_AREA_HEIGHT, st_itoa(fps));
/*dog_DrawStr(60+i, ST_AREA_HEIGHT, font_4x6, st_itoa(st_CntObj(0)));*/
void st_Draw(uint8_t fps)
switch(st_state)
case ST_STATE_PREPARE:
case ST_STATE_IPREPARE:
//dog_DrawStr(0, (st_u8g2->height-6)/2, font_4x6, "SpaceTrash");
u8g2_SetFont(st_u8g2, u8g_font_6x10r);
//dog_DrawStrP(0, (st_u8g2->height-6)/2, font_4x6, DOG_PSTR("SpaceTrash"));
u8g2_DrawStr(st_u8g2, 31, u8g_height_minus_one - (st_u8g2->height-6)/2, "Space Trash");
u8g2_DrawStr(st_u8g2, 18, u8g_height_minus_one - (st_u8g2->height-6)/2-15, "Pi BOTS MakerHub");
//dog_SetHLine(st_u8g2->width-st_to_diff_cnt-10, st_u8g2->width-st_to_diff_cnt, (st_u8g2->height-6)/2-1);
u8g2_DrawHLine(st_u8g2, st_u8g2->width-st_to_diff_cnt-10, u8g_height_minus_one - (st_u8g2->height-6)/2+3, 11);
break;
case ST_STATE_GAME:
st_DrawInGame(fps);
break;
case ST_STATE_END:
case ST_STATE_IEND:
//dog_DrawStr(0, (st_u8g2->height-6)/2, font_4x6, "Game Over");
//dog_DrawStrP(0, (st_u8g2->height-6)/2, font_4x6, DOG_PSTR("Game Over"));
u8g2_DrawStr(st_u8g2, 0, u8g_height_minus_one - (st_u8g2->height-6)/2, "Game Over");
//dog_DrawStr(50, (st_u8g2->height-6)/2, font_4x6, st_itoa(st_player_points));
u8g2_DrawStr(st_u8g2, 50, u8g_height_minus_one - (st_u8g2->height-6)/2, st_itoa(st_player_points));
//dog_DrawStr(75, (st_u8g2->height-6)/2, font_4x6, st_itoa(st_highscore));
u8g2_DrawStr(st_u8g2, 75, u8g_height_minus_one - (st_u8g2->height-6)/2, st_itoa(st_highscore));
//dog_SetHLine(st_to_diff_cnt, st_to_diff_cnt+10, (st_u8g2->height-6)/2-1);
u8g2_DrawHLine(st_u8g2, st_to_diff_cnt, u8g_height_minus_one - (st_u8g2->height-6)/2+1, 11);
break;
void st_SetupInGame(void)
st_player_points = 0;
st_player_points_delayed = 0;
st_difficulty = 1;
st_to_diff_cnt = 0;
st_ClrObjs();
st_NewPlayer();
/* st_InitBrick1(); */
/* API: game setup */
void st_Setup(u8g2_t *u8g)
st_u8g2 = u8g;
u8g2_SetBitmapMode(u8g, 1);
u8g_height_minus_one = u8g->height;
u8g_height_minus_one--;
/* API: game step execution */
player_pos: 0..255
void st_StepInGame(uint8_t player_pos, uint8_t is_auto_fire, uint8_t is_fire)
uint8_t i, j;
/* rescale player pos */
//st_player_pos = ((uint16_t)player_pos * (uint16_t)ST_AREA_HEIGHT)/256;
if ( player_pos < 64 )
st_player_pos = 0;
else if ( player_pos >= 192 )
st_player_pos = ST_AREA_HEIGHT-2-1;
else
st_player_pos = ((uint16_t)((player_pos-64)) * (uint16_t)(ST_AREA_HEIGHT-2))/128;
st_player_pos+=1;
/* move all objects */
st_Move(i);
/* check for objects which left the play area */
if ( st_objects[i].ot != 0 )
if ( st_IsOut(i) != 0 )
st_Disappear(i);
/* missle and destruction handling */
missle_mask = st_GetMissleMask(i);
if ( missle_mask != 0 ) /* should we apply missle handling? */
if ( st_CalcXY(st_objects+i) != 0 ) /* yes: calculate pixel reference point (st_px_x, st_px_y) */
for( j = 0; j < ST_OBJ_CNT; j++ ) /* has any other object been hit? */
if ( i != j ) /* except missle itself... */
if ( st_IsHit(j, st_px_x, st_px_y, missle_mask) != 0 ) /* let the member function decide */
{ /* let the member function destroy the object if required */
st_Destroy(i);
/* handle fire counter */
st_FireStep(is_auto_fire, is_fire);
/* fire */
st_Fire(i);
/* create new objects */
st_InitDelta();
/* increase difficulty */
st_to_diff_cnt++;
if ( st_to_diff_cnt == (ST_DIFF_VIS_LEN<width-10; /* reuse st_to_diff_cnt */
st_state = ST_STATE_IPREPARE;
break;
st_to_diff_cnt--;
if ( st_to_diff_cnt == 0 )
st_state = ST_STATE_GAME;
st_SetupInGame();
break;
case ST_STATE_GAME:
st_StepInGame(player_pos, is_auto_fire, is_fire);
break;
case ST_STATE_END:
st_to_diff_cnt = st_u8g2->width-10; /* reuse st_to_diff_cnt */
if ( st_highscore < st_player_points)
st_highscore = st_player_points;
st_state = ST_STATE_IEND;
break;
case ST_STATE_IEND:
st_to_diff_cnt--;
break;
void setup(void) {
u8g2.begin();
uint8_t a;
uint8_t b;
uint8_t y = 128;
void loop(void) {
u8g2.setFont(u8g2_font_6x10_tr);
u8g2.setFontDirection(0);
u8g2.setFontRefHeightAll();
st_Setup(u8g2.getU8g2());
for(;;)
st_Step(y, /* is_auto_fire */ 0, /* is_fire */ digitalRead(pin_fire));
u8g2.firstPage();
do
st_Draw(0);
} while( u8g2.nextPage() );
if ( digitalRead(pin_down) ) {
y++;
if ( digitalRead(pin_up) ) {
y--;
}<br>Step 6: Final Result
As a final thought, I really love this project. It was really easy to build and inexpensive. Of course, there is room for improvement. We can reduce the size of this console by using boards like Attiny85. Also, we can add a 3D Enclosure to make a pretty look for this cool game console and also for handy access.
I would love to hear your opinion about this project. Do you like how it looks and can you think of any improvements to this project? Please post your comments in the comments section below.
Thank You.
