Introduction: Speaker Holder
just a disclaimer steps 2-3 have very deceiving pictures that i measured completely wrong so instead of the picture I'll have the dimensions in the writing.But his photo is the right one
3d printer,
tinkercad,
about an hour
Step 1: Make a Base
this will ensure that everything stays in place
Dimensions:
L:110mm.
W:33mm.
H:128.11mm.
Step 2: Add a Cord Hole
a hole so the cord doesn't go around the whole thing and look bad as well as function bad.
Dimensions:
L:10mm.
W:63mm.
H:10mm.
Step 3: Add the Walls
walls so the speaker doesn't fall out of place.
Dimensions:
L:11mm.
W:75mm.
H:130mm.
Step 4: Finish & Customize!
now that your done you can put whatever you want as long as it doesn't block the speaker. In my case I put a right triangle on the walls to make it look sleek,I also added an emoticon right at the bottom so if you look real close in the picture then you might be able to see it. Anyway have fun Customizing your new speaker holder and I also hope you like it!
