Introduction: Speed Control of Dc Motor From Laptop Using Arduino and Processing
Hello everyone
I am vignesh raja. here i like to share the speed control of dc motor from computer using arduino and processing software. in this project the processing software run a simple application window on computer. based on the position of the mouse cursor in that window the processing send value to arduino using serial communication. Based on the value received from processing arduino controls the speed of dc motor using pwm.
Step 1: Circuit Connection
let us see the circuit diagram of this project. it is a simple connection. we have to connect the dc motor with arduino properly.
Step 2: Arduino Code
Here is the arduino code for this project
const int motorPin = 9;
void setup()
Serial.begin(9600); // initialize serial communication at 9600 baudrate
pinMode(motorPin, OUTPUT); // declare the motor control output pin
void loop() {
byte brightness;
if (Serial.available()) {
brightness = Serial.read(); //read value in serial communication
analogWrite(motorPin, brightness); // write the value to motor control pin as pwm
Step 3: Processing Code
processing is a gui software. it helps to create our own graphics using c++ code.
the link for download processing software
https://processing.org/download/?processing
here is the processing code for this project:
you can find your COM port number in which arduino is connected with your computer in below right corner of arduino software.
import processing.serial.*;
Serial port;
void setup() {
size(256, 150);
port = new Serial(this, "COM14", 9600); //replace COM port number in your laptop in which arduino is connected instead of COM14 here
void draw() {
for (int i = 0; i < 256; i++) {
stroke(i);
line(i, 0, i, 150);
port.write(mouseX);
Thank you for reading. see you all in my next instructable.
