Introduction: Speeds and Feeds
The blade speed and feed rate must be adjusted for each cut.
Step 1: Blade Speed Controls
The saw must be running to change speed.
- Use the chart to determine blade speed.
- Rotate the handle to change the blade speed.
- Read the blade speed on the scale.
Slow: Mild steel or stainless steel
Fast: Aluminum and plastic
Step 2: Feed Rate Control Panel
The feed rate control panel adjusts the vertical motion of the saw head.
- Lifts the head, while the button is pushed.
- Adjusts the feed rate.
- Selects the mode of the head.
- FEED - for cutting
- HOLD - no motion
- RAPID - for quickly dropping the head to the table; never for cutting
There are no hard stops for the three settings. Make sure the knob is pointed directly at the selected option.
Step 3: Adjusting the Blade Guide for Large Materials
To cut large materials, you may need to open the blade guides further.
- Push the e-stop.
- Loosen the lock knob.
- With a flat-head screwdriver, loosen the screw near the blade directly under the lock knob.
- Slide the blade guide to change the opening size.
- Snug the lock knob.
- Tighten the screw with the flat-head screwdriver.
- Reset the e-stop.
- Do a test cut to make sure blade is cutting squarely.
When finished, repeat these steps to return the guide to about a 6" opening.
