Introduction: Spherical POV
In this project , the concept of persistence of vision (POV) is used to generate a a pattern over a spherical surface using a circular strip of LEDS.The apparatus consists of 15 LEDs in a circular pattern rotating at a high rpm so as to form a persistence in human mind.
Step 1: MATERIALS REQUIRED :
- Arduino Nano
- 2 Shift Registers (74HC595N)
- 15 LED's
- 9 V Battery
- Protoboard
- DC Motor
- Lipo Battery
- Rotatory Encoder
Step 2: CONNECTIONS
- CONNECTION FOR SHIFT REGISTERS
- (QB) LED 2 +
- (QC) LED 3 +
- (QD) LED 4 +
- (QE) LED 5 +
- (QF) LED 6 +
- (QG) LED 7 +
- (QH) LED 8 +
- (GND) GND
- (QH*) -
- (SRCLR*) 5V
- (SRCLK) Digital 3
- (RCLK) Digital 4
- (OE*) GND
- (SER) Digital 2
- (QA) LED 1 +
- (VCC) 5V
- Ground for all the LED's should be common and connected to the common ground of arduino and shift register
- Similar connections can be done for 2nd shift register.
Step 3: CODE :
int datapin = 3; int clockpin = 6;
int latchpin = 5;
byte data2 = 0;
int datapin2 = 10;
int clockpin2 = 12;
int latchpin2 = 11;
int encoder_pin = 2;
volatile byte pulses;
long int newt=0 ,oldt=0;
long int interval;
int count = 0; bool a[15][60]={
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0},
{0,1,1,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,0,1,1,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,1,0,0,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0},
{0,1,1,1,1,1,1,0,0,0,0,0,0,0,1,1,1,1,1,1,0,0,0,1,1,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,1,0,0,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,1,0,0,1,1,0,0,1,1,1,0,0,0,0,0,0,0,0,0,0},
{0,1,1,0,0,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,1,0,0,1,1,0,0,0,1,1,0,0,0,0,0,0,0,0,0,0},
{0,1,1,1,1,1,1,0,0,1,1,1,0,1,1,0,0,0,0,0,0,0,0,1,1,0,0,0,0,0,0,0,1,1,0,0,0,0,0,1,1,0,0,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0},
{0,1,1,1,1,1,1,0,0,0,0,0,0,0,1,1,1,1,1,1,0,0,0,1,1,1,1,1,1,1,0,0,0,1,1,1,1,1,1,1,0,0,0,1,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0},
{0,1,1,1,1,1,1,0,0,0,0,0,0,0,0,1,1,1,1,1,0,0,0,1,1,1,1,1,1,1,0,0,0,0,1,1,1,1,1,0,0,0,0,1,1,1,1,1,1,0,0,0,0,0,0,0,0,0,0,0},
{0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0}} ;
void setup() {
Serial.begin(9600);
pinMode(datapin, OUTPUT);
pinMode(clockpin, OUTPUT);
pinMode(latchpin, OUTPUT);
pinMode(datapin2, OUTPUT);
pinMode(clockpin2, OUTPUT);
pinMode(latchpin2, OUTPUT);
attachInterrupt(0, counter, FALLING);
pulses = 0;
for(int index = 0; index <= 7; index++)
bitWrite(data1,index,0);
shiftOut(datapin, clockpin, MSBFIRST, data1);
digitalWrite(latchpin, 1);
digitalWrite(latchpin, 0);
for(int index = 0; index < 7; index++)
bitWrite(data2,index,0);
shiftOut(datapin2, clockpin2, MSBFIRST, data2);
digitalWrite(latchpin2, 1);
digitalWrite(latchpin2, 0);
}void counter()
//Update count
pulses++;
oldt=newt;
newt=micros();
interval=(newt-oldt)/2;
count=0;
void loop() {
pulses=pulses%60;
if (micros()<(newt+interval)){
bitWrite(data1,index,a[index][60-pulses]);
digitalWrite(latchpin, 0);}
// delayMicroseconds(1);
else{ bitWrite(data1,index,LOW);
bitWrite(data2,index,a[index+8][60-pulses]);
digitalWrite(latchpin2, 0);}
else{ bitWrite(data2,index,LOW);
if(micros()>=(newt+interval))
if(count==0)
{pulses++;count++;}
Serial.println(pulses);
}Step 4: POSSIBLE IMPROVEMENTS:
- Motor with inbuild encoder to be used to increase the accuracy.
- Mass must be accurately balanced with appropriate support .
- SMDs can be used instead of leds .
