Introduction: Spider Web With a Suction Cup
I made this easy spider web using pipe cleaners and wooden dowels. I put a suction cup on the back to make it easily come off and go on.
6 in by 1/2 cm wide wooden dowels
Black and white pipe cleaners
Suction cup
Step 1: Gluing the Dowels
Hot glue 4 of the 8 dowels together to form four right angles. Then take the other 4 dowels and glue them in between the others to make eight 45 degree angles.
Step 2: Adding the First Layer of the Web
Get a white pipe cleaner and curve it so that it fits in between two of the dowels like you see in the first picture. Then fold the ends like you see in the second picture.
Step 3: How to Add a Full Layer of Web
Wrap the ends of the pipe cleaner around the dowel on each side then cut away the access pipe cleaner repeat these steps in between all the dowels.
Step 4: Layers
You can add more layers by just making the curve bigger, I ended up adding 5 layers. You can use step 3 to help you.
Step 5: The Edges
Once you think you have enough layers wrap the ends of the dowels that are just wood with white pipe cleaners.
Step 6: Starting the Spider
Wrap a black pipe cleaner around your finger multiple times until you get to the end. Take another pipe cleaner and stick one end underneath one of the coils.
Step 7: The Lower Part of the Spider
Wrap the pipe cleaner around it the long way and then do it the short way.
Step 8: The Upper Part of the Spider
For the upper part of the spider only wrap the pipe cleaner around your finger 3 or four times. Then keep wrapping pipe cleaners around it switching between directions until it looks like the second picture.
Step 9: Attaching the Parts of Th Spider
To attache the parts of the spider stick one end of a pipe cleaner into the head and the other end through the body and cut off any extra pipe cleaner.
Step 10: The Legs
To make the legs fold a pipe cleaner in half and twist the halves together, then bend it like you see in the third picture. You will need six legs.
Step 11: Adding the Legs
You will need three legs on each side you can add a leg by just sticking it into the body. Once you have added all the legs glue the spider to the center of the web.
Step 12: Adding a Suction Cup
Get a suction cup and glue it to the back of the web in the middle. I bought suction cups from Micheals. I hope you enjoyed this instructables. :)
