Introduction: Spiral Ring
For this project first load up 3d auto max and click on torus
Step 1:
Next click in the middle of the graph and expand the circle
Step 2:
Edit the size with the dimensions for your ring size
Step 3:
Next below the radius options there are two named segmants and sides put segmants to 64 and sides to 24
Step 4:
Right click on the torus, and click on Scale which will make you able to adjest the height to your preference
Step 5:
Right click your torus at the bottem click convert to and make it editble poly
Step 6:
On the top left of your screen click polygon modeling.
Step 7:
After you do that click "Generate topology" and after click "edge Direction"
Step 8:
Now that you have changed the direction of your lines, click the square on the far right of your screen
Step 9:
Once again you must right click, but then click on "select"
Step 10:
Click once anywhere on your torus
Step 11:
Now while holding Ctr double click diagnal of where you originaly clicked and it should make a line.
Step 12:
While still holding control click next to your line
Step 13:
Then double click diagnal of that line again,you can make your lines thicker by repeating previous steps
Step 14:
Next you must click CTR and I at the same time
Step 15:
Next click delete on your keyboard
Step 16:
On the top right of your screen Click modifiers and use Turbosmooth and shell
Step 17:
After that is all finished transfer the file to whichever app you wish to use to 3d print your project
