Introduction: Spitfire Necklace
This awesome necklace is a tribute to the Young Justice couple, Kid Flash and Artemis. This breathtaking bedazzlement will be the center of many conversations and can be worn on any occasion!
3D printer
Needle nose pliers
Very small paintbrush
Low grit sandpaper
Neckless chain
Neckless ring
Yellow acrylic paint
Green acrylic paint
Step 1: Printing Your Necklace
The first step to making joyful jewelry is to print the charm. Load the printer with white or clear filament, then let the printer do the rest!
Once the printer has finished, carefully pull the charm off. There will be a few ruff edges, so lightly run the sandpaper over any imperfections.
Congratulations, you survived step one!
Step 2: Painting
The next step in your journey is to paint the heroes' signature colors onto the charm. Starting with the yellow paint, carefully cover the lightning bolt portion of the emblem. Apply a few coats, letting the paint dry between each one.
Once the lightning bolt is finished, crack out the green paint and cover the arrow! Use the same number of coats as you used with the yellow.
Step 3: Putting It All Together
Almost done!
Take you neckless ring and carefully slide it around the top of your charm, so that the loop at the top and the ring are linked together. Use your pliers to clamp the ring closed so that it doesn't fall off.
The last thing you have to do is slide your chain through the ring.
You now have a spectacular Spitfire neckless!
