Introduction: Spongebob : Krab's First Dollar
Anyone remembers that episode where Spongebob and Patrick repaint the house of M. Krab? The episode is Wet Painters. I wanted a Spongebob props and this was one of the simpliest to do so if you're a fan of Spongebob this is for you! The material to use :
- Bamboo pole
- Paper
- Cardboard
- A background for you frame like in the pictures... ( I used old fiberglass cloth)
Step 1: Cut Your Bamboo
The size of the frame is 8 1/2'' x 11'' (like a normal sheet of paper). The diameter of the bamboo is 1 1/2''. First, cut all the corners in a 45 degree angle.
Step 2: Glue Your Frame
I used hot glue to assemble the frame.
Step 3: Paint Your Background
The only thing I found in my home with a "linear" background was my old fiberglass cloth. So, I cut it with the same dimension of my frame and I painted it in gray. (with spray paint)
Step 4: Glue Your Background
Simply glue your background at the back of your frame
Step 5: First Dollar
Print the first dollar and DON'T FORGET to add the white spot that Spongebob made. ;)
Step 6: Frame Signature
Ok, I forgot to take some pictures here but I used 2 layer of cardboard. I engraved Cap. Krab in the first layer and I glue it to the second. I Paper Mache the result and I painted it in Chrome color.
Step 7: Final Result
An easy DIY project for everyone for cheap. Hope you enjoyed it, any comment is welcome.
- John, from Canada
