Spray Paint Stencils
Intro: Spray Paint Stencils
Here is a fun hobby to start. I like to spray paint designs on different things. You can use your own photos or uploaded photos.
It's really simple to do. Just read through and try it out.
If you have any questions don't be afraid to comment below.
STEP 1: Supplies
What you'll need:
-Newspaper
-Cardstock with a black and white print of photo
-Gloves (optional)
-Cutting board
-Spray Paint (any color)
-X-Acto Knife
-Object to put your design on (I'm using a paper for an example)
-Room to work
-Newspaper
-Gloves (optional)
-Cutting board
-X-Acto Knife
-Room to work
STEP 2: Cut Out Stencil
Before you even begin, you need to choose what you would like to make a stencil of. Print it out in black and white, this will help make cutting it out a lot easier. If it has a lot of detail, it will be harder. I like to print it out on cardstock because it is less flimsy as normal printer paper and will keep its shape better.
To begin, all you'll need is the cardstock with the design on it, the X-Acto knife, and the cutting board.
Please be patient! Depending on your design, it may take some time and patience to cut it out.
ONLY CUT OUT THE BLACK!
Sometimes there will be a white spot in the black, if so: cut it out and save it. You can add it on later by using double sided tape.
Please be careful not to cut yourself.
STEP 3: Spray Paint Time
Next get ready to spray paint. I like to spray paint outside to vent the fumes, but whatever works best for you.
I lay out newspaper underneath whatever I'm going to spray paint.
Then I lay out the stencil where I want it to be.
Lay more newspaper over the rest so it doesn't fly everywhere else.
During all of this I wear gloves so I don't get spray paint all over myself.
Shake the spray paint really well, on most cans they say up to 2 minutes... I don't usually shake them that much.
Spray over your design, you might want to apply pressure around your design as your spraying so it doesn't run underneath your design.
Let it dry!
Let it dry!
STEP 4: Your Creation
After it dries you can either: put a coat of clear coat or be done with the spraying.
Remove the stencil and reveal your work.
If it does not turn out the way you wished, practice makes perfect.
If you find another way of making this easier, comment below for others.
Enjoy spray painting! :)
15 Comments
sansari1 6 years ago
thehbird 10 years ago
omnibot 12 years ago
user1044 12 years ago
BlueSuns 12 years ago
leovinci 12 years ago
ilpug 12 years ago
ilpug 12 years ago
dmadru 12 years ago
O-Budd-1 12 years ago
dmadru 12 years ago
dimtick 12 years ago
whenever I've done stuff like this it seems to help it if what I'm spraying is mounted vertically. that way I'm holding the spray paint can vertically, then spray in light coats.
now for cutting, it really helps to get yourself one of those green cutting mats. when you cut on wood, it will get scratch's and grooves on it which will throw off your cut. also change the blade often. need good crisp cuts. any "fuz" in the cut is gauranteed to bleed.
good job!
