Sprinkles Ring/Pendant
Intro: Sprinkles Ring/Pendant
If you're searching for a simple, cheap but pretty and colorful jewel, you' re in the right place. This could be nice for you or as a gift, for a friend.
STEP 1: Ring's Tools & Supplies
- Syringe (withour needle)
- Mixing bowl
- Stir stick
- Butane Torche or Lighter
- Beer cap
- Sprinkles
- Epoxy Resin
- Adjustable Blank Ring
SOME OF THE LINKS IN THE DESCRIPTION ARE AFFILIATE LINKS
This means that by using them I earn a small percentage of your purchase, without charging you anything extra.
STEP 2: Ring
- Pour the sprinkles in the bottle cap and arrange them as you like.
- With the syringe, drain equal amounts from the two parts of the resin and pour them in the small mixing bowl.
- Stir the two parts with a wooden stir stick until you have a homogeneous mixture. Don't worry about the bubbles, we'll blow the most of them.
- With the syringe drain the mixture and pour it on the sprinkles and be careful to spread it on the inner edges of the bottle cap.
- Let the bubbles emerge on the surface and blow them with the flame of the butane torch. Be careful not to burn the resin.
- Let the resin dry at least overnight on a flat, horizontal surface. To protect your project from dust, you can cover it with a bowl for some hours and then uncover it.
- When your project dried completely, glue the ring on the other side of the bottle cap using a strong glue or (as I like to do) use the same resin you used to cover the sprinkles.
STEP 3: Pendant's Tools & Supplies
- Rotary tool
- Drill bit
- Cutting plier
- Round needle nose plier
- Mixing bowl
- Syringe (without needle)
- Wooden stir stick
- Butane Torch
- Beer cap
- Sprinkles
- Epoxy Resin
- Jewelry Wire
- Necklace cord
STEP 4: Pendant
- Choose a beer cap. I chose mine by its colour. I think that bright colours fit better in this project. You can choose your cap by your favourite beer or logo too.
- Find a drill bit with the same size as the jewelry wire and drill a hole on the beer cap.
- Cut the wire, bend it at one end to remain on the beer cap (mine has a nail head, so I didn't have to do this) and pass it through the hole.
- With the round needle nose plier bend the other end of the wire to form a loop.
- Pour the sprinkles on the cap and rearrange the pieces as you like.
- Pass the necklace cord through the loop and you are ready to wear it!
2 Comments
SophieBdoesart 7 years ago
Suki_ete 7 years ago
