Introduction: Make a Stage! - With Roll Out Bed!
Ever wanted to make a stage?.. Well now you can!
I do DJ gigs and I was running out of space to put my DJ gear, So why not build a stage?
This project took me just over a 3 weeks from drawing the plans to the finished project. I enjoyed this project and it was probably one of the best projects i've undertaken!
I hope you enjoy this project!
Oscar
Oscar
Step 1: Materials and Tools
Materials:
16 x 33cm of 2'' x 4'' kiln dried wood
2 x 120cm of 3'' x 2'' kiln dried wood
6 x 238cm of 3'' x 2'' kiln dried wood
100mm screws
Loft boards
40mm screws
Paint
75mm screws
Tools:
Drill
Screw driver
Saw, I used B & Q cutting service to cut it
Measuring tape
Level
Counter sink
100mm screws
Loft boards
40mm screws
Paint
75mm screws
Tools:
Drill
Screw driver
Measuring tape
Level
Counter sink
Step 2: Making the Legs
To make the legs you will first need:
75mm screws
First Place two of the 33cm lengths of 2'' x 4'' wood next to each other, like picture one. Then join them together like shown in picutre 3 with a 75mm screw, one on each side. Remember to drill a pilot hole and counter sink the hole.
Repeat this 8 times and you've done the legs!
75mm screws
Step 3: Assembling the Legs
Firstly you will need to decide what size you stage is going to be.. If you are having a pull out bed I would recomend nothing over 2.5m wide. Other wise it can be as big as the whole room! I would also note where the plug points are so you can access them.
My stage measured 238cm by 120cm. I will give the instructions for my size stage.
First lay two legs, 120cm apart (Or how wide you stage is) at each corner of your room then lay one in the middle of those two (at 60cm). Next lay 2 legs at 80cm Increments (beetween each side of the stage at the back). Lay them at were the back of your stage is going to be.
Step 4: Stage Frame
To assemble the stage frame you will need:
100mm screws
First place the 120cm lengths on wood at each end of the stage, like shown in picture 1. Once you have done this drill a pilot hole for the screw and then screw a 100mm screw through the 120cm lengths of wood then into the leg.
Next place 1 length of wood measuring 238cm across the back of the stage and then screw it in like shown before.
Note: Place the length of wood a bit from the back like shown in picture 9.
After that place two lengths of wood measuring 238cm across the middle like shown in picture 7. Each piece of wood should have 5cm resting on each leg. Screw these down and then screw them together.
Repeat it for the front and you've finished the frame!
100mm screws
Step 5: Stage Platform
To make the platform for the stage I used loft board. I used 7 boards measuring 13'' each. The loft boards worked really well as they are strong, durable and they can interlock.
Firstly lay as many loft boards as you need on to the stage. You may need to cut them a bit shorter if there are any wall sockets. Once they are all in position screw them in with 40mm screws.
After all of that is done you can paint it, I chose to paint mine white!
Step 6: Pull Out Bed and Units.
I used the Ikea ODDA pull out bed, Its not too expensive and its colour blended very well with my stage. It comes with instructions, so I don't really need to upload them.
I also chose to have a cabinet to hold some of my DJ equipment which also came from ikea. I mounted a desk as well (which I made my self) from two large shelf brackets and some laminated wood.
Now your finshed!
Now your finshed!
Step 7: Your Finshed!
I hope you enjoy the stage and the build!
Thanks for looking!
Oscar
Thanks for looking!
Oscar
