Introduction: Standalone Atmega8-16pu With Arduino Optiboot Bootloader
This instructable is made because I experienced various problems to make Atmega8-16pu to run Optiboot Bootloader, so I want to share how I finally can use Atmega8-16pu with Optiboot Bootloader
There are many advantages of using Optiboot Bootloader, including:
1. Larger uploadable sketch size due to bootloader's smaller size.
2. Faster startup (Instant startup vs Arduino NG Bootloader's 8-10seconds startup)
Step 1: Parts & List
You are going to need:
1. Atmega8-16pu (1)
2. 22pF Capacitor (2)
3. 16MHz Crystal (1)
4. Arduino UNO (1)
5. 10K Resistor (1)
6. Jumper Wires
Step 2: Breadboarding
Assemble the components according to the picture above.
At Atmega 8:
Pin 1 > 10K resistor to +5V & Wire to Pin 10 Arduino UNO
Pin 7 > +5V
Pin 8 > Ground
Pin 9 > 22pF Capacitor to ground & Crystal
Pin 10 > 22pF Capacitor to ground & Crystal
Pin 17 > Pin 11 Arduino UNO
Pin 18 > Pin 12 Arduino UNO
Pin 19 > Pin 13 Arduino UNO
Pin 20 > +5V
Pin 22 > Ground
Step 3: Burning the Optiboot Bootloader Using OptiLoader
Download and upload optiLoader sketch to Arduino UNO ( Link: https://github.com/WestfW/OptiLoader )
Open serial monitor and set Baudrate to 19200 with Both NL & CR
Type 'G' if nothing appears in Serial Monitor
The burning process should be started
The finished process should be appears like the second image above
Step 4: Uploading Sketch to Optiboot Burned Atmega8
Plug your Atmega8 to Arduino UNO (Replace the Atmega328)
(or use some kind of FTDI Adapter to program it)
Download and extract Arduino IDE 1.0.5 ( Link: http://arduino.googlecode.com/files/arduino-1.0.5-... )
Open the extracted folder and navigate to \hardware\arduino and open the board.txt file using WordPad (don't use Notepad)
Go to the lowest line and paste this text:
opti8.name=Arduino Optiboot-Atmega8-16
opti8.upload.protocol=arduino
opti8.upload.maximum_size=7680
opti8.upload.speed=115200
opti8.bootloader.low_fuses=0xbf
opti8.bootloader.high_fuses=0xcc
opti8.bootloader.path=optiboot
opti8.bootloader.file=optiboot_atmega8-16.hex
opti8.bootloader.unlock_bits=0x3F
opti8.bootloader.lock_bits=0x0F
opti8.build.mcu=atmega8
opti8.build.f_cpu=16000000L
opti8.build.core=arduino
opti8.build.variant=standard
Save it and run arduino.exe in the root directory of the extracted folder
Choose Arduino Optiboot-Atmega8-16 in Tools>Board
Choose your Serial Port in Tools>Serial Port
You should can upload sketch without any problems. (I tested to upload Blink sketch)
Step 5: Enjoy!
Congratulations!
Your Atmega8-16pu now loaded with Optiboot Bootloader and you can use it just like Atmega328p-pu with instant startup and larger sketch room.
The pin diagram is the same with Atmega328p-pu ( Image from: https://www.instructables.com/file/F2SFHSDH3Z3V3P4/ )
Credits:
Optiboot ( https://code.google.com/p/optiboot/wiki/Installing... )
WestfW's OptiLoader ( https://github.com/WestfW/OptiLoader )
board.txt modification from wkws20's eBay Listing (http://www.ebay.com/itm/3pcs-Arduino-MCU-ATMEGA8-1... )
