Introduction: Star Destroyer
One of the most famous Star Wars ships
cardboard
Hot glue
Sizers
Ruler
Paint
marker
Step 1:
get a piece of cardboard and cut a piece 1 ft straight 1 ft 2in just a little more slanted and 5in a little slanted and cut that out and do two of them and glue the two together
Step 2:
and do the same of thing and glue it to the other one
Step 3:
You will get a two 5in long pieces and cut the dizine in the picture and then glue it to the star destroyer
Step 4:
And then you will cut two pieces of cardboard 2 1/2 wide 3 1/3 long and glue those together and then glue it two the star destroyer
Step 5:
and then you will get a piece of cardboard 2cm wide and two in long and then you will bend the top of the piece of cardboard
Step 6:
Then you will cut a piece of cardboard 1 1/2 in slanted and then you will cut 1 cm wide 1 1/2in straight up and then glue it to the star destroyer . Check out the pictures.😀
Step 7:
Patern 1cm 2cm1cm 2cm 1cm and the bottom is 2in twice.And you will glue those two together.And glue that to the star
Step 8:
And now we will add the engines to the space ship. You will make seven engines you will get seven circles for the engines and then you will glue it to the star destroyer three big engines and four small engines.
Step 9:
and then you will paint the star destroyer you will get a black marker to do the diziness and after that you will paint it light gray and that will finish the star destroyer.
