Star Shaped LED Jewelry
Intro: Star Shaped LED Jewelry
Hi All,
Few months back I came across an instructable https://www.instructables.com/id/LED-Jewelry/ by jiripraus
I wanted to try the making one, for my wife and she wanted a Star shaped LED jewelry. I did a google and could not find any template for it. So I decided to make one myself
In this instructable I will share how to design and make your own led jewelry
STEP 1: What Do We Need ?
- Brass wire 21 Gauge ( approx 0.9mm)
- LED Strips ( white ) or smd LEDs
- CR-2032 battery
- Soldering iron
- Paper tape
- one A4 Sheet
- Pencil, compass, and a measuring scale
- Cutter
- Pliers Small
- Multi-meter
STEP 2: SMD LED
- I extracted my LEDs from an old LED strip
- These were white SMD LED
- Approx 3 mm X 2 mm X 1.5 mm ( L x W X H )
- Had a T sign on it which indicated the cathode for the LED
- Carefully de-solder these leds from the strip
- I needed 6, but i extracted 9 of these, just to be sure that I had enough to work with
- Test the LEDs to make sure they are still working, replacing LEDs later is bit difficult
STEP 3: Design Principles
- The jewelry has to be as compact as possible, we need to use the smallest battery avaliable
- We are not building a torch, do not use extremely bright LEDs
- Joints should not have sharp edges
- It should look simple and elegant
- Measure the battery, LEDs and wire
- My Battery was 20 mm in diameter
- The star is made with a circle with 40 mm diameter, one could chose to make it more bigger depends on one's preferences
STEP 4: Star Outline
- Trace the outline with brass wire
- To get better star shape we have to cut the brass wire as shown and then soldered the joints
- Stick the wire in place using paper tape
- Remember to file the joints, so that there are no sharp edges
STEP 5: Add LEDs
- The Star outline will be connected to positive end of the battery
- So solder anodes of all 6 LEDS to the star as shown
- Add joints to connect all cathodes of 6 LEDs as shown
STEP 6: Add Hook
- Since this is a going to be a pendant, We need a hook
- Twist and cut a small hook of brass wire
- Solder it flat to the star
STEP 7: Battery Support
- On the back , we will add two battery supports to hold the CR 2032 battery in place
- one of the support is as the diameter and another at the bottom
STEP 8: Finishing
- Inspect the LED jewelry for week joints and add soldering where needed
- Insert the battery and test all LEDs
- Hook it in a chain and we are done
I hope this instructable will inspire you to design your own shape and make one
thanks for reading
4 Comments
ДженниРакета 4 years ago
Nice build!
Amit_Jain 4 years ago
KarloHorcicka 4 years ago
