Introduction: Starfish Bracelet
Hi guys! LambyAngel is here. I'm back! I'm sorry for no Instructables. Anyway, I'm going to teach you the "Starfish Bracelet" by RainbowLoom. So...let's get started!
Step 1: MATERIALS
For this RainbowLoom bracelet you will need/
1) RainbowLoom kit
2) Hook (metal is better)
3) RainbowLoom bands
4) C-clip
That's all you will be needing. Lets move on!
1) RainbowLoom kit
4) C-clip
Step 2: PLACING BANDS
Let's start placing. Make sure that your loom is in a rectangular configuration. Make sure that that the arrow is facing up. So start placing the border. Place a band (aqua marine) from the middle peg to the left peg. Same with the right. Then place 12 bands upward on both sides. Then close it like at the start. Push every thing down. Put a capping band on the top. Now let's do the design. Get your 2nd color (orange) and put one band from the 1st left peg to the 2nd middle peg. Same with the right. Then put a band from the 2nd middle peg to the 3rd left peg. Same with the right. Then do the same with your 3rd color (pink). Do this 4 more times, alternating the colors.
Step 3: LOOPING BANDS
Let's start looping the bands. Get your hook (mine is metal). Turn the loom around so that the arrow is facing you. Go through the capping band and loop the top band to the left. Same with the right. Then then loop the top left peg to the middle. Same with the right. Then loop the bottom left band forward. Same with the right. Then go loop the top band on the 2nd middle peg to the left. Same with the right. Then loop the bottom band on the 2nd peg on the left forward. Do the same with the right. Do this again until you're done with your done with your loom. After you're done loop the bottom left band to the middle band. Same with the right. Tie off with your border color band and add extensions if needed
