Introduction: Static Shock (absorber) Discharger to Never Get Shocked by Static Again.
Lately I get static shocks a lot. I'm not sure if it is the dry weather, my shoes or my car. Or it might be all of the above.
Every time when I get out of the car and touch something metal I get a terrible static shock. Most of the time it is my car door handle.
Something has to be done!
I couldn't find a solution on Instructables so I had to find my own solution. I thought it might be an idea to discharge myself through a resistor. I tried a 1.5M resistor and it worked perfectly. (other resistors might also work)
I could just bind a 1.5M resistor on my keychain, but I wanted to make something nicer, so that's what I did.
Step 1: You Will Need
materials
- metal tube
- plastic tube
- resistor 1.5M
- non conductive O-ring
tools
- metal saw
- sander
- solder stuff
- pliers
- snips
- multimeter (optional)
Step 2: The Tubes
- Find a metal tube that fits the resistor inside. (I used brass)
- Find a plastic tube that just fits the metal tube. (I have no idea what my plastic tube was in his previous live)
- Sand (or file) a nice chamfer on one site of the metal tube.
- Cut it as short as possible while it still is long enough to stay in the plastic tube. (1 cm worked for me)
- Cut an other piece longer for the back. (2 cm or something like that)
Step 3: Put It Together
- Cut the plastic tube long enough that it mostly covers the chamfered tube and just the straight tube.
- Put the O-ring around the resistor.
- Put the resistor with the long lead towards the chamfered side. (most resistors have leads that are the same side, so than it doesn't matter how you put it)
- The O-ring should divide the two metal tubes.
- Snip the wire that sticks out on the chamfered side, flush with the tube.
Step 4: Solder the Resistor
- Solder the snipped wire to the metal tube. I soldered it with a nice dome for looks.
- Bent the wire on the other side back into the tube, so you get a ring on the back.
- Solder the bend wire on the back to the straight tube.
- (optional) measure if the resistance between the two tubes. It should be 1.5 M
Step 5: Finish It
- Push the plastic tube over the metal tubes to connect them. You might need glue to keep it stuck.
Now the thingy is finished.
Use it:
- To use it you hold one side in your hand. (the straight side)
- You need to touch the metal, but NOT the metal on the chamfered side.
- Touch something metal with the chamfered side to discharge yourself.
- Never get shocked again!
