Introduction: Stealth Running
This will help you run quietly, like a ninja!
Step 1: 1)Before You Can Run, You Must Learn to Walk!
Give a general description of the StepStart barefoot and walk around on your tip-toes, like a cat. If you notice they are silent and do walk on there toes! Your toes ofer the most padding pluss you can easily move around mostly using muscles in your ankle!
Step 2: 2)Practice
First practice where it would be easiest to be silent, on carpet! Walk around on your toes like a cat but be careful not to step on things. The reason is not as you may expect, It is not so you won't hurt your foot (which is also a concern) but because what you step on may cause a noise! Start slowly and keep your eyes glued to the floor, use peripheral vision to navigate and avoid obstacles until you can see obstacles without looking a it.
Step 3: 3)Running
By now you should easily creep around at a brisk pace without being noticed. Slowly try going faster than you could befor. Eventualy you should be able to run around without being noticed.
Step 4: 4)Use Your Newly Developed Skill!
You can use your ninja like skill! Just sneak up behind people but instead of asassination by means of a weapon, scare them to death!!!
Mwhahahahahahaha!!!!
