Steam Punk Ammo Tin Nixie Clock
Intro: Steam Punk Ammo Tin Nixie Clock
I was inspired by other home made nixie clocks I had seen online and thought I'd have a go myself. I used an old ammo tin, vintage moving coil gauges from the 1940s and a switch from a 1960s airliner to give this clock a military feel. These parts were all sourced cheap from eBay, there is a wealth of interesting kit out there!
This project requires a lot of soldering to complete. There are also dangerously high voltages involved so some previous electronic experience would be advantageous. I used the Dink board from PV electronics to power the lights, a great all in one kit that I'd recommend. This instructable is more of a rough guide and wont go into minute details as a lot will have to be figured out by the builder :)
The basic components used for this build are:
- 30 cal ammo tin
- Dink PV Electronics Board
- 6 nixie bulbs (i used IN-12A tubes)
- 6 nixie bulb holders
- neon lights
- wire mesh
- push to make buttons
- M3 bolts nuts and washers
- M3 Nylon Standoffs
- 12V DC power supply
- Tesa Tape
- shrink tube
- wire
Tools Required:
- dremel with plenty of cutting disks or Jigsaw
- grinding disks
- soldering Iron
- drill
- ccrewdriver
- Tin Snips/Metal cutters
- Multimeter
STEP 1: Design
Sketch your design ideas for your clock. If you know the dimensions of your components you can make a 3D model to check the fit and look of your final clock. I used Sketchup to mock up my designs.
STEP 2: Electronics
- Follow the dink board instructions and solder the board together.
- Once this is complete begin on the lights.
- First solder one row together, joining the same pins in a line like this. I used shrink tube to prevent short circuits.
- Leave a longer lead (about 20cm) on one end. This will be connected to the dink board. The PV instruction manual details this process nicely.
- Once the harness is complete insert the tubes into the holders and connect to the board to test.
- I used tesa tape to tidy up the wiring and give the lights a more vintage look.
- I made a holder for the lights by bending the wire mesh into a U shape and using 3mm nuts and bolts to hold the lights in place.
- I used the 5V supply from my arduino and a breadboard to test the vintage electronics.
A resistor is required for the moving coil gauges to read a value. It needs to be mounted in series. I found by trial and error that a 150 ohm resistor worked for my Voltmeter gauge.
- Once tested the moving coil gauges measuring current and amps were connected to the 5v supply point on the dink board.
- Push to make switches were wired up and connected to the switch points on the dink board.
- The large power switch is used to turn the clock on and off. It is mounted on the 12V power cord line.
STEP 3: Cut Out Windows in the Ammo Tin
- I used a dremel to cut out the windows in the ammo tin. Make sure you have plenty of disks as they quickly disintegrate. A jigsaw would probably work better.
- Sand the edges to get rid of burrs.
- I used a drill and counter sink to create the holes for the red switches.
- Cut the wire face plate mesh to size using tin snips or a dremel.
- Test fit everything and check for sharp edges before moving on.
STEP 4: Final Assembly
The final assembly is fiddly but fun.
- I used 3mm nuts and bolts to hold the light assembly in place.
- 3mm Nylon standoffs are a neat solution to hold the dink board away from the metal case.
13 Comments
brmarcum 7 years ago
This is really cool. Nice build and good instructions.
kenyer 7 years ago
This really inspires me to also go do something with the Nixies that I have for a couple of years already. Really great project!
themanwoaname 7 years ago
this is dieselpunk.
https://en.wikipedia.org/wiki/Dieselpunk
KISELIN 7 years ago
Just 1 comment on You'r ideable, them pushbuttons aren't "just" of the vintage. Love this Instr...... me FIN hard to spell the Instr....
KISELIN 7 years ago
Sorry.. NOT Dixie-tube but Nixie-tube
KISELIN 7 years ago
DIXIE- Tubes, or "Tyhjiönäyttöputki" as we called them here in Finland. Pro-pro-before-pro father, (or mother) to 7-segment display. There were 10 different filaments, ( 1 for each number 0-9, like in a lightbulb). Then came James Bond having fhis AMAZING wristwatch
Ancient Android 7 years ago
Well done ! The best Film prop.
Note to self : Ammo Tin Nixie Clock ( count down timer ) build
Roddy Scott 7 years ago
Nice work on the casing for the clock! Different from what you normally see.
I like the DINK kits as they give a lot of flexibility with design and I am the build stage of yet another that will feature GN-4 tubes and a Dekatron in an Atomiun based design.
Look forward to see more from you.
Cheers!
rgeelen 7 years ago
more dieselpunk then steampunk. i still like it though
the dan of many trades 7 years ago
Very post apocalyptic looking, very nice.
KeriSzafir 7 years ago
Way more post-apoc than steampunk, IMO. I love this Interplay Fallout look :).
jbike 7 years ago
Nice construction. Inspires me to try something like this.
DIY Hacks and How Tos 7 years ago
This looks awesome. Nicely done.
