Introduction: Steam Punk Pipe Lamp
I had seen a lot of these lamps, but none really appealed to me. So I built by own. Follow along and let build it.
Step 1: Electrical
Start by figuring out the wiring setup. I found it best to get the lamp working before trying to figure out containing it all inside the pipes.
Good luck getting the wires correct in there
I used a normal socket and a salvaged power cord. Everything started right up. Just splice and solder the wires up and shrink wrap with electrical tape. Done.
Step 2: Playing With Your Pipe......
Gather your parts of pipe and really just play around until you find a shape you like. I must have done 6 different shapes until I decided on this one. Just take your time and play around.
Once you have a shape decided on, you need to figure out where the electrical cord will exit the lamp. I decided on the rear of the center support brace. I was able to put the pipe in a vice and drill out a hole large enough to easily pass the cord through. Hint: make sure you smooth out the drilled hole or you will cut into wire. Not good.
Step 3: Final Paint and Assembly
This is the final shape mine took. Build the lamp halfway and then with each piece of pipe pull the wires through. Repeat until you'll assemble the lamp completely.
After several light coats of flat black paint it was starting to look good. Also painted the handle bright red. This should give a pleasant contrast of colors.
Wrap your power cord in painters tape to ensure it doesn't turn black as well...
Step 4: Attaching the Switch
The on/off switch was wired into the valve in the front. Found a switch at Home Depot that was small enough to fit and I "glued" the inner valve stem to the switch. Crude yes but it works.
The entire valve assembly is attached with industrial epoxy. Clamp it over night and it should never come off
Step 5: Enjoy Your Cool Lamp.
Here is the lamp fully assembled and working for the first time. Don't mind my dirty bench, that is from a chest of drawers we are resurfacing.
Finally here is the lamp in its home on my table and usually on my desk for work. I chose a low wattage Edison bulb merely because I likes it.
I may add a shad to it one day, I doubt it though, I like it a lot.
Keep working and moving forward.
PS. I have a few orders for more of these things from my coworkers, I guess I'm on to something.
