Introduction: Steampunk Sky Raider Jetpack With MP3, LEDs & Fog Machine
Please Note: Due to the heat of the Fog Machine, I have added three new items;
1 3-Way "T' Heater Hose Connector (3/4") 19mm Auto Zone ( Spray Paint Gold)
1 Heater Hose Connector (3/4") 19mm Auto Zone
3 Feet - Heater Hose (3/4") 19mm Auto Zone
This cost $15.00 Bucks and works way better.
You will need:
2 Cans Krylon Metallic Brilliant Gold Spray Paint
1 Can Krylon Fusion Hammered Fine Bronze Spray Paint
1 Can Gray Primer Spray Paint
1 Can Goof Off
2 bags - 6ft universal connect dishwasher discharge hose with clamps by homeworks worldwide (home depot)
3 Empty Plastic Soda Bottles - one clear 3 liter Coca-Cola bottle and, two clear 2 liter sprite zero bottles
Gloves
Fine Grit Sandpaper
3M Double Sided Tape
Mp3 Player
Small Speakers
Speaker Gril Thingy
Cool LED Lights
Back Pack
Adhesive Backed Velcro Strips
X-acto Knife
Fog Machine
Fog Juice
www.spirithalloween.com/product/400-watt-fog-machine/
You will need:
1 Can Goof Off
Gloves
Fine Grit Sandpaper
Mp3 Player
Small Speakers
Speaker Gril Thingy
Cool LED Lights
Back Pack
X-acto Knife
Fog Machine
Fog Juice
Step 1: Remove Labels & Glue From Bottles
1. Take three empty plastic soda bottles and pill off the labels.
I used one clear 3 liter Coca-Cola bottle and, two clear 2 liter sprite zero bottles.
Remove the two green cap rings.
Spray on some Goof Off to remove the label glue and lightly scrap off the gunk. Rinse the bottles inside and out, then let dry.
Step 2: Sand & Cut Bottles
2. Use a fine grit sandpaper to lightly ruff up the plastic soda bottles just enough to remove the shine.
Cut the bottoms off the two 2 liter sprite zero bottles.
I use a lighter two bevel the ends inward and give them a flared look..
Cut a flap in the back of the 3 liter large enough for your hand to fit and a small round hole in front for your speaker grill.
NOTE: Latter I use a plastic thingy from an air freshener as a speaker grill.
I thought it would be easy to glue on the 3 liter but, I was wrong.
I used cool looking tacks to keep it in place. So, decide before cutting, what your going to use as a speaker grill.
If your good at cutting with an x-acto knife, you may want to use the stencil I made. I was originally going to use it and glue fine black mesh fabric to the inside of the bottle.
Step 3: Prime Bottles
3. Shake the primer sealer really good, then spray and coat the plastic bottles.
I used a gray because I wanted a dulled look, use a white if your working with a foil spray paint or just want a brighter look.
I did not like working with the primer sealer, it was runny. =(
Step 4: Spray Paint Bottles
4. Spray both 2 liter bottles with Krylon Metallic Brilliant Gold.
5. Shake the Krylon Fusion Hammered Fine Bronze really good.
Its ok if at first the paint looks green. Shake the can a little more and coat the 3 liter lightly, let dry and repeat until completely covered. Wile the bronze was still wet, I gave the bottle a fine mist of gold.
Step 5: Spray Paint Hose & T Connector
6. Cut one universal connection off the end of your 6ft hose. Cut the other 6ft hose in half (3ft) .
Note: You may have to cut off both ends to your 6ft hose to fit it on your fogger.
Spray Krylon Metallic Brilliant Gold on the hoses and 3-way T hose connector
7. t-pipe, wash, dry and, paint gold.
Note: This round thing is what I used as a speaker grill. It was sanded, primed and, painted bronze with a mist of gold.
Then I glued three layers of fine black mesh fabric to the inside or the grill.
Step 6: Hoses & Connecting Explained
Frist, connect heater hose to pipe connector
Next, connect other end of pipe connector to 6ft hose
Now, connect other end of 6ft hose to bottom end of T-pipe connector
Connect each 3ft hoses to left and right sides of T-pipe connector
Connect each universal connector (3ft hose) to left and right cap top
Last, connect heater hose to fogger before use
Disconnect heater hosse after flight
Step 7: Assemble Jetpack
8. Wipe down bottles with a damp towel and cut two, 4 inch strips of 3m double sided tape. Line up your two side bottles and place tape on the inner sides, just out of view. Slowly slide the middle bottle forward, this should give your jetpack a “Mickey Mouse Ears” look.
Add your LED lights to the inside of your two side jets. I used the 3M tape for this too.
9. Slide on one 3 foot hose onto the top of each side jet
10. Connect the three ends of the hoses to the T-pipe
11. Place Mp3 player and speakers into the big bottle
12. Add Velcro to the back of the big bottle and back of your back pack.
STICK IT TOGETHER!!! WE ARE ALMOST DONE WITH OUR JETPACK!!!!!!!! =D
Step 8: Preflight Checklist & Shout Outs
13. Connect fogger to heater hose and place the connector onto other end of hose. Now connect the 6ft dishwasher hose together with the fogger hose.
14. Plug in and let your fogger warm up for a bit after adding some fog juice.
15. Turn on your music and LEDs, put on your Steampunk Sky Raider Jetpack, turn on your fogger and JETOFF!!!
16. Have a great time with your new Steampunk Sky Raider Jetpack, and tell your all friends about this cool Intractable.
Shout Outs -
Special Thanks To:
SANVA - San Antonio Neo-Victorian Association - Facebook
San Antonio STEAMPUNK Society - Facebook
*SASSE* San Antonio Steampunk Society Of Engineers - Facebook - http://www.wix.com/alexiseshem/home
Shout Outs -
Special Thanks To:
