Steampunk Themed Christmas Tree
Intro: Steampunk Themed Christmas Tree
This is for all the steampunk fans out there, or people looking for a non-traditional Christmas tree. The whole tree has been made using recycled materials that I found around my house. It is mainly cardboard and common recycled bits and bobs. I must warn you the process looks like something the cat chucked up but the final results were great.
STEP 1: Making the Gears
The gears were all made from a regular cardboard box. Using a large compass I made some circles for the gears. I cut out 4 circles the biggest being 25 cm and going smaller by 5 cm each circle. You can use a craft knife to cut out the circles.
STEP 2: Making a Template
I found some images of gears that I liked and printed them off to use as a template. The paper gears were glued onto the cardboard as a cutting guide. You can use a sharp knife to cut out the cardboard.
STEP 3: Adding Texture to the Cardboard
Nobody wants a cardboard Christmas tree, so I wanted to disguise the fact that is was cardboard. To do this I used some texture paste and stencils. Place the stencil over the cardboard and apply some texture paste over the stencil using a spatula then remove the stencil. This step does not need to be neat or tidy it will all be hidden by paint. It really does not matter what stencils you used because this is just the basecoat. You will see the benefits of this step later. I used a few different stencils on each gear. This step is just added randomly.
STEP 4: Fix My Gear
I messed up on this gear and accidentally cut out the centre. So I had to cut some cardboard to glue to the bottom to fill in the hole so it will attach to the pole. The texture on this gear was created by adding a layer of texture paste and pushing it down into the sand. It is not special sand It was my niece's sandpit.
STEP 5: Find Embellishments
Because I do mixed media art, I collect every little piece of junk I find at home to add to my projects. I used mainly broken jewellery from thrift stores and junk from my workshop on this tree. The clear embellishments were made using resin and silicone moulds. And some charms were bought in bulk from Amazon and China.
STEP 6: Add the Embellishments to the Gears
To glue the embellishments onto the gears I used craft glue for the small items and fabric and hot glue for the rest. The idea is to randomly cover the gears and layer the embellishment to get a 3-dimensional effect. I have added close-ups of the gears so you can see the items that I used there are too many to name. You can use just about any junk because it will all be painted. There is no need to put everything perfectly or to be overly concerned about any messy glue. This will all add to the effect at the end.
STEP 7: Paint the Gears
Next, use some black gesso to paint everything making sure to get into all the nooks and crannies.
STEP 8: Highlight the Paint
This is where the magic happens. Using copper wax paste you can now highlight the raised surfaces first. Touch the surface of the wax using your finger and rub some over all the raised surfaces. The idea is not to cover all the black, you still want the two-tone effect.
STEP 9: Fill in Some Gaps
Once all the raised surfaces are covered, you can add a very light coat to the rest. I like to use a soft makeup brush with the tiniest amount of colour on and add it to some of the flat surfaces. You are not trying to paint it just highlight small areas. It will look like the second image when you are finished. Some of the gears in this and the previous step look very dark because they were taken at night, that is not the true colour.
STEP 10: Making the Stand
To make the stand, I used a piece of wood and a threaded plate. I had the plate and threaded pole in my shed so I have no idea what it is called. It was left behind by the previous owner. You can screw the plate into the wood and screw in the threaded pole. The gears are held in place using nuts above and below each gear. Once I put it together it did not resemble the idea I had in my head. I did not like the look of the threaded pole.
STEP 11: Hide the Pole
I cut a small piece of pipe of my greywater pipe that I use to water my garden. This was painted black and highlighted with the copper wax paste. Because I make my projects up as I go along I do tend to change things as I build. I get new ideas along the way.
STEP 12: Make Some Baubles
The Christmas tree still looked to plain to me so I made some steampunk style baubles from Styrofoam balls and old Christmas decorations. And that is my steampunk themed Christmas tree done.
STEP 13: More Christmas Projects for You
This corner Christmas tree shelf can be used at Christmas to display all your Christmas decorations. After Christmas, the shelf can be used as a regular display shelf until the next special occasion.
STEP 14: Christmas Sign
Extra-large Christmas signpost to go with all your Christmas garden decorations. For more great DIY projects pop across to my website Unique Creations By Anita
4 Comments
_willow_ 3 years ago
AnitaH25 3 years ago
StumpChunkman 3 years ago
