Introduction: Steel Ball in Wooden Cage
The steel in a wooden cage makes for an excellent distraction while you are relaxing at home.
While travelling on holiday, I visited a woodwork shop and picked up some small scrap pieces of wood, including a hardwood call 'black wood'. Back home I wondered what to do with the pieces of wood and knew I had a short window of opportunity as they would soon be assigned to be a 'sometime project'. This steel in a wooden cage project follows on from making a noise maker and uses a similar carving technique.
Scap piece of wood
Dremel like drill
Saw
Sandpaper
Aluminum or Steel ball
Step 1: Bit of Cutting
The scrap piece of wood I had was an odd shape and needed to be cut into a rectangle. This was done with a hand saw.
Step 2: Bit of Sanding
The wood was the smoothed with different grades of sandpaper, I started with 40 grit, as it is very aggressive and finally finished with some 120 grit sandpaper.
Step 3: Bit of Marking
Draw rails around the edges. I made them 6mm from the edge and used the 'old builders' trick' of gliding the pencil with one finger resting on the wood as a glide.
Step 4: Bit of Drilling
- Hold a ruler along the drawn lines and attach it with some blue tac.
- Drill very small holes next to each other just deeper than the rail's width, along the edge of the ruler.
- Move the ruler to the other corner edge, secure with blue tack and drill more holes.
I discovered hard wood is difficult to drill and it turned out to be more a burning of holes than cutting, with the drill needing to cool down after drilling a few holes.
Step 5: Bit of Carving
- Use a carving knife or pocketknife with the smaller blade, cut away the wood.
- Do this around the other edges and remove the waste wood in the middle to make a wooden cage.
Step 6: More Carving
Once to bulk of wood has been removed, use the blade of the knife to tidy up where the drill holes have been made.
Step 7: More Sanding
Sand to make smooth, using different grades of sandpaper.
Step 8: Fitting a Ball
I had read that by socking the wooden cage in hot water for half an hour the wooden rails would become flexible enough to insert a sold ball. But I found it didn't have much of an effect on the hard wood and I realized if a solid ball was inserted the cage would break. As I didn't want to do this, another approach was required.
My approach was to roll up a piece of aluminum foil into a ball and compressed it by tapping with a hammer. This created a hard aluminum ball which still had enough give to be able to squeeze into the wooden cage.
Some weeks later I found you can buy different sized steel ball from AliExpress, so I replaced the aluminum ball with a 20mm steel ball. By squeezing the aluminum ball out as the steel ball was squeezed in this created an opposing force which prevented the wood from breaking.
Step 9: Oil It Up
Oil the wood with a suitable wood oil to bring out the colours of the wood.
