Introduction: Stefans, the Easy Way
Is your mind boggled by all the complicated Stefan designs? New to making Stefans? Well this Instructable might just be for you! I will be covering how to make blanks, straightening said blanks, and weighting them.
Step 1: Materials
A knife, 1/2 foam backer rod or caulk saver, airsoft BBs, hot glue gun and glue, and a piece of 1/2 CPVC cut to the length of the Stefan you want.
Step 2: Cutting
Slide your FBR into the pipe, do not let any hang out of one side, cut off the rest on the end as shown. Now push it out.
Step 3: Straightening
Place your blanks in a pillow case, and tie it. Put it in the dryer. Set it to medium heat, for 15-20 minutes. When it's finished take the, out of the dryer.
Step 4: Weighting and Stuff
Burn a hole in the center end of your blank with the glue gun. Now place a BB in it, next glue over it. Let it dry.
Step 5: The End
Now load them into your Nerf gun, blowgun, or whatever. And as always, have fun, and stay safe! Note, these require the barrel post, or a barrel mod to work in Nerf blasters
