Introduction: Step Display Stand 3 Layers
本展示架使用雷射切割製作,用5mm的板材即可。
適合放置本身就能立著的物品,不適合立著放置如明信片等物品。
可以拆裝,移動時可以拆掉方便攜帶 組裝層板時注意圓角的位置,即可對到卡榫,安裝完成。
高度15公分、寬度28公分、長度30公分 每層高度5公分,每層長11公分,版厚0.5公分
因為有肋的設計,所以雖然只有0.5cm的厚度仍然可以長時間支撐3公斤的重量,不會變形
This display stand is made by laser cutting, and it can be made of 5mm plates.
It is suitable for placing items that can stand on its own, but not for placing items such as postcards.
It can be disassembled and removed when moving, and it is convenient to carry. When assembling the laminate, pay attention to the position of the rounded corners.
Height 15 cm, width 28 cm, length 30 cm Each layer is 5 cm high, each layer is 11 cm long, and the plate thickness is 0.5 cm
Because of the ribbed design, even though it is only 0.5cm thick, it can still support a weight of 3 kg for a long time without deformation
Step 1: 將檔案放入雷切機中(Put the File in to Laser Machine)
每種雷射切割機的使用方式不同,請依照自己的機台來將檔案放入雷射切割機中。
本範例以FLUX 的40W,CO2雷射,Beambox為例。
1.下載兩個dxf檔案
2.事先下載並打開Beam Studio
3.開啟檔案
4.設定位置與功率
5.儲存
The use of each laser cutting machine is different. Please put the files into the laser cutting machine according to your own machine.
This example takes FLUX's 40W, CO2 laser and Beambox as an example.
1. Download two dxf files
2. Download and open Beam Studio in advance
3. Open the file
4. Set position and power
5. Storage
Step 2: 開始切割
把檔案放入機器中,放入5mm的板材,開始切割。
完成後拿出
Put the file into the machine, put in a 5mm plate, and start cutting.
Take it out when you are done
Step 3: 組裝
切割完成後開始組裝,需要準備白膠,如圖片所示步驟組裝
After the cutting is completed, start the assembly, you need to prepare white glue, as shown in the picture to assemble
