Introduction: Stereo FM / AM Radio Receiver With VU Meter (TEA5711 + LM386)
In this project, I will show you how to build a high-quality Stereo FM / AM Radio Receiver using the TEA5711 radio IC, dual LM386 audio amplifiers, and a 10-LED stereo VU meter.
This radio is based on a personally tested and fully working prototype. It offers clear FM stereo reception, AM band support, adjustable tuning, volume control, and a real-time visual audio level indicator.
📺 Full Step-by-Step Build Video:
This project is suitable for:
- Electronics hobbyists
- DIY radio enthusiasts
- Students learning RF and audio circuits
Step 1: How the Radio Works (Block Overview)
The circuit is divided into four main functional sections:
- FM / AM Radio Receiver Module (TEA5711)
- Stereo Audio Amplifier (2× LM386)
- Stereo VU Meter Display (TA7666P / KIA7666P)
- Power Supply & Voltage Regulation
Each section is explained step by step in the following sections.
Step 2: FM / AM Radio Receiver Module (TEA5711)
The heart of this project is the TEA5711, a high-performance integrated FM stereo and AM receiver IC.
Key Features:
- Supports FM Stereo and AM in a single IC
- Operates at low supply voltage
- High sensitivity and stable reception
Important Components:
- Ceramic IF Filters (Y2, Y3 – 10.7 MHz):
- Ensure proper FM IF selectivity
- FM Antenna (AE1): Telescopic antenna input
- AM Antenna (L2): Ferrite rod antenna
- Variable Capacitor (C26): Manual tuning control
- Protection Diodes (D11, D12 – 1N4148):
- Protect antenna input from static discharge
This section handles all RF processing, mixing, IF amplification, and demodulation.
Step 3: Stereo Audio Amplifier (2× LM386)
The low-level audio output from the TEA5711 is amplified using two LM386 ICs, one for each channel.
Features:
- True stereo audio amplification
- Compact and efficient design
Important Details:
- Dual Potentiometer (RV2 – 50K):
- Controls volume for both left and right channels simultaneously
- Gain Boost Capacitor (C15 – 10µF):
- Increases LM386 gain to maximum
- Zobel Networks (R21/C19 and R27/C41):
- Prevent high-frequency oscillations and ensure stable output
This stage drives standard 8Ω speakers directly.
Step 4: Stereo VU Meter (TA7666P / KIA7666P)
This section adds a professional visual element to the radio.
Features:
- 10 LEDs total (5 per channel)
- Real-time audio level display
Technical Notes:
- TA7666P IC: Stereo level indicator
- Current Limiting Resistors (1.2K):
- Protect LEDs from overcurrent
- RC Networks (C5/R9 and C12/R13):
- Control response speed and sensitivity
The VU meter reacts smoothly to music and speech signals.
Step 5: Power Supply & Voltage Regulation
The radio operates from a 9V DC source (battery or external adapter).
Power Design:
- Input: 9V DC
- Regulated Output: ~5.6V for the radio section
Key Components:
- Zener Diode (D14 – 6V2)
- Transistor Regulator (Q1 – 2SC1402)
- Large Filter Capacitors (C1, C2):
- Reduce noise and ripple
This ensures stable operation and minimizes background hum.
Step 6: PCB Design and Layout
The PCB was designed specifically for low noise and easy assembly.
PCB Highlights:
- Wide GND traces to reduce interference
- Clear silkscreen labels for all components
- Optimized placement of:
- AM IF transformers
- Ferrite antenna
- RF-sensitive components
Control elements (Tuning, Volume, AM/FM switch) are aligned for easy access.
Step 7: PCB Production (Heat Transfer Method)
For DIY PCB manufacturing, mirror-image copper layouts are provided.
Tips:
- Print at 100% scale (1:1)
- Use mirror images for iron-on transfer
- Verify IC footprint alignment before etching
Incorrect scaling will prevent DIP ICs from fitting properly.
Step 8: Assembly & Calibration Tips
- Solder low-profile components first
- Install RF components carefully
- Adjust AM IF transformers gently
- Keep antenna wiring short
- Follow the soldering order shown in the video
📺 Assembly Video:
Step 9: Final Result
Once assembled and powered:
- Clear FM stereo reception
- Stable AM reception
- Clean stereo audio output
- Smooth VU meter response
This project combines RF design, audio electronics, and visual feedback in a single build.
Step 10: More Projects
If you enjoyed this project, check out my other electronics builds:
🔹 DIY FM Radio with Arduino & Si4703
🔹 Powerful AM/FM Radio with CXA1019S
🔹 Arduino LC Meter
🔹 Home PCB Manufacturing Techniques
▶ YouTube Channel:
