Introduction: Steven Universe Cookie Cat Necklace
In this instructable i will be showing you how to make a polymer clay cookie cat necklace from Steven Universe.
Cookie cats come in chocolate and vanilla and you can make either or, however I will be showing how to make a vanilla cookie cat.
Step 1: Supplies
- White, brown and yellow(not pictured) clay for the cookie part
- White and pink clay for the icecream filling
- an eye screw or glue-on bail
- Necklace chain
- paper and pencil
- something to cut with (xacto knife or a small pallet knife)
- rough grit sandpaper (for texture)
Step 2: Cookie Part
First mix small amounts of brown and yellow clay to achieve a vanilla cake coloured clay, as shown in the first picture.
Next, draw a template for your necklace. I started with an oval and added ears.
Decide where you're going to position your bail or eye pin/screw
Now flatten your clay, place your cut out template, and with a up and down sawing motion cut your first piece out.
Repeat to cur out a second piece. You may need to reshape and flatten your clay to make room.
Finally, cut two holes in one cookie piece for eyes. (I used a clean straw)
Step 3: Two Toned Filling and Assembly
Shape your white and pink clay into semi circles, then place them together.
Flatten if needed to fit your template on (The filling should be thicker than the cookie part).
Then Piece together the sandwich and insert your eye screw or pin. Mine was a little thick so I Put the Bail in between the back and the ice cream.
Texture the cookie with the sandpaper to your liking and bake according to your clay's instructions
Glue on your bail (if you didn't add it in) and feed your chain though the eye pin or bail and enjoy your handmade necklace!
