Introduction: Stone Maze Game
Maze is one of the interesting puzzle in the world. It enhances your cognitive and logical thinking .
So, lets begin to create our own diy stone maze in which there will be random holes to increase the difficulty of the game and a cardboard tray where stones will get stored whenever they fall from the holes.
To make this following materials will be required--:
- Cardboard
- stones
- Hot Glue gun
- Marker and stationary
- Thermacol cutter
Step 1: To Make Board and Maze Structure
Get ready with the materials and with the help of thermacol cutter cut out 30*30 cm two pieces of cardboard which will serve as base and the inner box of our maze.
Now, draw the blue print of maze in the paper through the help of the above image or internet and trace exactly the same design on the cardboard base.
Cut out four strips of 30*5 cm cardboard where four will be used in maze border and next four will be used for border on inner box which will work as pillar for our maze
Step 2: Making the Base
Once everything has been assembled, then join the borders. In one border there should be a hole so that when marble get inside of a hole in the maze It can be get back.
Step 3: Making Maze
Draw a Maze on a paper. The maze should have some holes because they will make it harder.
Now after you have traced the maze on a 30*30cm cardboard stick 2.5cm high strips of cardboard on the lines of maze.
Border the maze form all four sides with 30*2.5cm cardboard. And the maze part is ready
Step 4: Time to Play
Now assemble the Maze by sticking the maze and the base with glue gun.
To play you need to mark the Start and the Finish Point any where you want. Now put a marble on the start point and by tilting the maze you can move the marble to the finish point
