Introduction: Stool
Here are the steps on how to make a nice looking stool.
Step 1: Cut Wood
Cut 4 pieces of 1x2 in. wood to 12 inches. Then cut 4 pieces of 1x2 in. wood to 18 in. Then 4 pieces 2x2 in. wood to 15 inches.
Step 2: Drilling
Use a pocket hole guide set to 3/4in.
-Using the pocket ogle guide, drill all of the holes for the clamped down pieces of wood -By using the pocket hole guide, it allows you to drill into the wood at an angle -Put the pieces of wood in place and hold them there -Then using the drill and the correct drill bit, drill the nails into the holes which will connect the two pieces -Do this all of the way around until all of the pieces are connected.
Step 3: Canvas
Then cut canvas that is 2 inches wide to the appropriate length to stretch across the stool and wrap under the piece of wood
-Then use a tack and hammer to put the piece of canvas into place -Then do the same all for all of the sides and then weave the pieces of canvas through each other
Step 4: Finished Product
Place your new creation somewhere desirable.
