Stop Snoring for Less Than 3 Dollars
7,043
15
6
Introduction: Stop Snoring for Less Than 3 Dollars
I have a snoring problem, or should I say my wife has a snoring problem because of me.
While I’m asleep it doesn’t bother me, but I Love my wife and I want her to be happy.
Also, after using this device I get a better nights rest and feel better in the morning.
When you are asleep your muscles relax letting your tongue and other structures partially block your airway. This makes the snoring noise but more seriously reduces the amount of oxygen getting to your body. The effects range from poor sleep to dangerous sleep apnea. If you are experiencing the more serious symptoms like morning dry mouth, headaches and are chronically tired you may have symptoms of sleep apnea and should see a doctor about that.
There is another instructable author here by the name of "snore" that describes how to use a premade mouthpiece. He has a link to device descriptions and prices that may interest you, however the solution I will be describing is a true DIY solution for the most common snoring problem.
I looked into those anti-snore devices I have been hearing about on radio ads but they are expensive. They range in price from $50 for the cheapest to several hundred dollars for the most expensive but they all do the same thing.
They work by pulling the jaw forward and opening the airway at the back of your throat.
I came up with an easy test to see if my idea would work for me. I laid on my back, which is the position that produces the worst snoring for me, and thrust my jaw forward . The snoring sound stopped so I knew that a mandibular device would work for me.
Now how do I make a DIY version?
All these devices looked like the mouth guards we used playing football in high school so I thought it would be worth a try to make one to see if it works before I shell out the cash for the commercial one.
I bought a two pack of mouth guards at our sporting goods store and the cost was less than three dollars.
Step 1: Cheap Custom Mouthpiece
these are the boil and fit custom mouthpieces used for sports
Step 2: Prep the Mouthpieces
cut off the "leash" part of the mouthpieces and trim the pieces to fit your mouth. The red one will be the top piece and the black will be the bottom for this example. you do not need for the bottom piece to be as big as the top piece
Step 3: Custom Fit
follow the directions on the package to mold the mouthpieces to your mouth both top and bottom.
Step 4: Glueing the Halves Together
put both pieces in your mouth and test by using the method described earlier. When the lower jaw is in a position to stop the snoring, use your finger to feel the front of the two pieces. This will let you know where to "glue" them together. In this example I used the cut off leash straps and melted them with a propane torch as my glue but I have used a hot glue gun and this works very well. just place the pieces together just as they were in your mouth. Feel the front making sure that they line up as before. Make note of were they come together then put a bead of hot glue and replace them in that position,
Test again to insure a close fit. then I run a bead around to seal the pieces together. After the glue has cooled I make one last adjustment. Using tongs, I dip the top piece only in to the hot water and I want it to fit the top teeth but not be tight ( if it is too tight your teeth may hurt in the am) now dip and set the bottom the same way. You will want enough of the material coming down behind the bottom teeth to keep the jaw in place. I sometimes have to pull it down a little with my fingers before inserting in my mouth
Hope this works for you .
Be the First to Share
    • Big and Small Contest
    • For the Home Contest
    • Game Design: Student Design Challenge
    6 Comments
    xhavertov
    xhavertov
    Question 9 months ago on Introduction
    Hi, what type of hot glue would you usually use for this, and does it matter if the temperature is high or low? Please and thank you 😁
    megaloler9000
    megaloler9000
    Question 2 years ago
    hi!! im trying to do one of these, and my problem is that after the top and bottom pieces are glued in place to hold the jaw forward, and when they are in my mouth, my jaw simply falls downwards and out of the mouth piece, (and thus unable to be held in a forward position) i'm wondering how to deal with this problem ? o:
    sdavisrt
    sdavisrt
    Answer 2 years ago
    Hi megaloler you may try to mold the bottom piece so that it extends downward more. In the most recent version I just melted the straps to glue the guards together before I boiled them. I then heated them in hot water and made sure my mouth was in the jaw forward position. Using my own suction and help with my tounge pressed the bottom part downward while molding it in my mouth. I then trimed it and used a lighter to smooth the edges. It does take a little trial and error but when you get it right it works for a while . I've been using my current one for almost a year now.
    greal5208
    greal5208
    4 years ago on Step 4
    Most of the commercial devices have a hole that allows air flow between the front teeth... I've made my own bite block using a guard on my upper teeth, and found that resecting the portion between my incisors was helpful to improve airflow.
    sdavisrt
    sdavisrt
    Reply 4 years ago
    thanks for you reply greal5208, I had thought about making one from a mouthpiece that already has a cutout, but I usualy breath through my nose anyway unless I have a cold or somthing. Next time I make one I will try it.
    sdavisrt
    sdavisrt
    5 years ago
    I recently discovered that if I use a hairdryer to heat up the two mouth pieces they will get sticky enough to "glue" together without the hot glue making the process faster and easier. the mouthpieces last about 6 months till Im ready for another one
