Introduction: Story Tin Pendant Necklace
Some stories never get old. Decorate a tin to keep a pendant necklace from the pages of your favorite book. You might want to make at least two of this project-- one to gift and one to keep for yourself to wear!
- Favorite book that you would like to use the pages from. (Make a copy and print out a page if you don't want to cut up the book.)
- 2 inch tin (I got these at a local Dollar Store)
- 1.5 Inch hole punch
- Scissors
- Optional: sharp blade
- Paint brush
- Mod Podge glue/sealer
- Pendant tray base (I used a 1" round. You can use any other size too.)
- Glass cabochon that fits inside the pendant
- Clear glue
- Necklace cord or leather strap with fixings attached (or add you own ends, clasp and o-ring)
- Small pliers
- Store bought beads
- and/or your own paper beads
Step 1: Preparing the Pages From Your Book
Carefully cut out some pages from your book.
Step 2: Gluing the Paper Strip Around the Bottom of the Tin
Cut some strips of paper the width of the lower edge on the bottom of the closed tin. Use your paint brush to brush a layer of Mod Podge all around the bottom edge of the tin. Apply a paper strip or two (they can overlap). Rub it smooth onto the tin. Apply top coat of Mod Podge with a paint brush.
Step 3: Cutting Out Some Circles for Your Tin
Use the 1.5 Inch circle cutter to cut out some selected circles for the top of your tin. Glue the circle to the top of the tin with Mod Podge.
Step 4: Adding a Few More Details to the Top of the Tin
Cut some extra slices of paper to add more detail to the top of your tin. Brush on with Mod Podge. Carefully smooth out with your finger if needed.
Step 5: Selecting and Cutting Pages From Your Book for Your Pendant
If you need more book pages for your pendant, start again by cutting out a few more book pages. Cut out the circles this time with the 1 inch circle cutter (or with scissors). Trim off some of the page if it helps you get to a better choice of text. Cut out a few more circles than you need- you can evaluate your final choice later. (Watch all the way through this video. Step 6 will go into detail about gluing the paper and glass cabochon to the pendant tray base.)
Step 6: Gluing the Book Page Circle to Your Glass Cabochon and Pendant Tray Base
Choose a cut out circle from your selection. Pick one whose text goes with your theme! Apply a thin layer of clear glue to the back of the glass. Gently press down and smoosh the paper to the glass in order to get any bubbles out. Apply the glue to the pendant tray base. Apply the prepared glass to the pendant tray base. Gently push down on the glass to adhere it to the pendant tray base.
Step 7: Stringing Your Necklace Cord With the Pendant and Some Beads
String the decorated pendant and beads of your choice to a pre-made necklace cord with fixings or string them onto a necklace cord/leather strap that you add you own ends, clasp and o-ring in optional Step 8.
Step 8: Optional. Adding the Jewelry Fixings If Your Don't Have a Pre-made Cord
Use your pliers to attach the ends to your cord. Squeeze to hold the ends in place. Attach the clasp and o-ring to each end.
Step 9: The Grand Finale! Adding Your Necklace to the Tin!!
Pull your pendant and beads together front and center on your cord. Wrap the back of the cord around and behind the pendant and beads. Carefully place in your tin. Place the lid on the tin. Stand back and enjoy your creation!!
