Introduction: Strap Wraps
Quick hack for tie down straps- increase contact friction to improve holding power by making these simple sleeves to slip on tie downs.
Friction is a function ofsurface contact area, force and the coefficient of friction. When I car-top my kayaks, these three variables are what I have to work with.
Ratcheting up the force is the simplest way to increase the holding friction. However, this can strain and stress a boat, an expensive investment to damage!
Commercial racks increase the surface contact area with special cradles. Unfortunately, these are expensive and reduce the general function of the rack.
Sleeves of non-slip rubber to augment the friction easily secure my boats. It's cheap and general, rather than brute force or elaborate racks. A more simple solution.
Step 1: Materials and Tools
Materials:
Tools I found useful:
Step 2: Construction
Fabrication is straightforward, however, most flexible epoxies release poisonous vapors so work in a well ventilated area.
- Unroll the non-slip material and cut in 12" sections.
- Lay out sections on top of non-permeable paper.
- Apply a thick bead of epoxy in a 2" wide - zig-zag along on edge.
- Fold non-slip material over, onto the epoxy.
- Use a spatula to press the flaps together and keep your fingers clean.
- Let cure per the epoxy's instructions, outdoors preferably.
Step 3: Wrap-up!
Simply slide the sleeves over what you use for tie-downs. My initial wraps have lasted 6 years of use and actually hold better as they've gotten worn and wrinkly.
I've also found that there is no longer any need to ensure my tie-down straps lay flat across my kayak. In fact, when the sleeves bunch up, and twist around the straps, I get the best holding power. An awesome tertiary advantage, I can throw the straps on sloppy and quick- with better performance!
