Straw Finger
Introduction: Straw Finger
About: Hi there! Hopefully these guides can help inspire you to tinker, be curious, play, contribute, and learn. If you're here for pandemic-related PPE and want more, check out our Something Labs website at somethin…
Give those flesh and bone fingers a rest and try out a brand new plastic one! This is a way not only to creep out yourself, but also get an introduction to a thing or two about anatomy. You can make just one finger or an entire hand!
The details:
  • What: A straw finger!
  • Time: ~ 5 minutes
  • Cost: ~ 3 cents
  • Materials: Tape, Straw (large), Zip-Tie
  • Tools: Scissors
  • Concepts: Muscles, Tendons, Tension, Force, Anatomy
Step 1: Measure and Cut Zip-tie
Feed your zip-tie through your straw so that it sticks out a little bit on either side. It works well to use the fastener end as a handle to pull with, so cut the other end if it feels too long. Take the zip-tie back out for the next step.
Step 2: Cut Holes for Joints
Time to make the joints of the finger. Fold the straw and cut a triangular slice out. When you unfold it, you fill you've made a diamond-shaped hole.
You'll want to do it again a bit farther down the straw such that the holes are lined up on the same side of the straw. This is where the straw finger will bend.
Step 3: Attach Zip-tie
After you have your joints, time to affix your tendon to the end. Feed the zip-tie back through and fold it over the end of the straw to tape it. You'll want to tape the zip tie on the side of the straw where your holes are for easy bending.
Step 4: Make That Finger Wiggle!
You'll want to bend the finger a bit at the joints to crease them a little bit for easy bending. Then wiggle away! Feel free to cut more joint holes to make a crazy alien finger. Or cut them on different sides to see it warp in truly strange ways.
In this model, the straw is modeling bone (though connected, sure), the zip-tie as a tendon, and the force of your hand pulling as a muscle. You can have students compare their own finger movement, and see if they can trace their tendons up their hand.
A brief educational page on tendons and hands can be found here!
1 Person Made This Project!
  • Fabric Challenge
    Fabric Challenge
  • Backyard Contest
    Backyard Contest
  • Stone Concrete Cement Contest
4 Comments
steflenk
steflenk
7 years ago on Introduction
:) :) :) If you want to take this a bit further, I stumbled on this tutorial about a month ago for something most similiar: https://www.stanwinstonschool.com/tutorials/make-a-cable-controlled-mechanical-hand
The Oakland Toy Lab
The Oakland Toy Lab
That is indeed the great extreme version, and neatly the same mechanic used a bunch of the low-cost 3D-printed prosthetics coming out. Thank you for sharing!
AzureRaven99
AzureRaven99
7 years ago
Run a string just a bit longer than the straw through the inside. Attach to top snd let excess string hang from the bottom. Pull on the string to flex your finger.
