Introduction: Straw Whistle
This is a super simple project in which you will make a whistle out of a plastic straw and hot glue. it is easy to make and gives a great sounding whistle.
Step 1: Materials
For this project few materials are needed but you will need:
- Plastic Straw
- Hot Glue
You will also need some tools:
- Hot glue gun
Sharp-Blade Knife
Step 2:
First you will need to cut half way through the straw about 0.5 inch from the beginning of the straw. Then you will need to cut at an angle into the straw to make a slit. Then you will need to cut the straw to the right length. The shorter it is the higher the note the longer it is the lower the note.
Step 3:
Next you will need to cut two 0.5 inch pieces from the remainder of the straw you cut. Next you will need to put them vertically and fill them with hot glue. Once it is dry you will need to cut off the excess glue you should have two cylinders when you are done.
Step 4:
Next you will need to cut one of the cylinders more than half way from the top. The you will need to put it in the front of the straw and then with the hot glue gun melt it on to the top. Remember you will want to leave a small hole at the top.
Step 5:
Then you will need to cut the stopper for the whistle, you will put it at the end of the whistle and then melt it on with the hot glue gun.
Step 6: Conclusion
I'm not sure if I was clear enough in explaining the steps, but I think the photos will help. Also if you have any questions please don't hesitate to ask. Suggestions and corrections are appreciated. I hope you enjoyed making this Straw Whistle.
