Introduction: Strawberry Shortcake Tart (with Microwave Pastry Cream!)
Strawberries, whipped cream, and spongy cake - few things are more awesome at a summer picnic than strawberry shortcake. With all the same flavors, this tart is easy to prepare and requires only minimal oven-time thanks to a yummy cookie crust, microwave pastry cream, and delicious fresh berries.
Makes one 9" tart
Makes one 9" tart
Step 1: You'll Need. . .
Software
For the crust
Hardware
1I made pastry cream in the microwave, but you could do it in a pot on the stovetop if you'd like
For the crust
- 11 shortbread cookies
- 2 tablespoons butter, melted
- 2 tablespoons sugar
- 1 cup heavy cream
- 1 1/2 tablespoons cornstarch
- 1 large egg yolk
- 1 teaspoon vanilla extract or vanilla paste
- Approximately 12 medium-sized strawberries
- About a tablespoon of sugar
Hardware
- Medium-sized microwave-safe mixing bowl
- Whisk
- 2 small mixing bowls
- Microwave
- Measuring cups and spoons
- Knife and cutting board
- Food processor
- Large spoon or small drinking glass
- 9" tart pan with removable bottom
Step 2: Getting Crusty
- Preheat oven to 350 degrees Fahrenheit
- Add your shortbread cookies and sugar to the bowl of your food processor
- Mix until the cookies have become crumbs
- Slowly add in the melted butter and mix until combined
- Pour out the crust mixture into your tart pan
- Using the back of a spoon or a small glass, press the crumb mixture against the sides and bottom of the tart pan
- Bake for 6 minutes, and then remove from oven and allow to cool slightly
- Transfer to refrigerator and allow to cool fully
Step 3: Microwave Pastry Cream
I made pastry cream in the microwave (you can also make lemon curd and risotto and even Bearnaise and Hollandaise sauce in the microwave!), but you could do it in a pot on the stovetop if you'd like - I just prefer not to heat up my kitchen too much in the summertime (or Chicago in mid-March when it's 80 degrees out for some reason).
- Whisk together the cream, cornstarch, and sugar in a microwave-safe bowl
- Microwave on high for 1 minute
- Whisk and then heat for another minute
- Repeat heating for one minute and mixing until the mixture thickens slightly (usually 2 - 3 minutes)
- In a small bowl mix together the egg yolk and vanilla
- Mix a few teaspoons of the hot cream mixture into the egg and vanilla and then mix the egg mixture into the cream
- Microwave for 30 seconds and then whisk
- Repeat heating for 30 seconds and whisking until the mixture thickens
- Transfer to a small container and refrigerate until ready to use
Step 4: Berry Berry Good
- Wash and dry your strawberries
- Remove the tops and slice
- Place in a bowl with about a teaspoon of sugar
- Let sit at room temperature or in the fridge until ready to use
Step 5: Assembly
- Remove the outer ring of your tart pan, holding the base of it in your hand
- Place the tart crust on your serving plate
- Spoon in the pastry cream and spread evenly
- Top with slices of strawberry, working around the edge and moving in to the center
- Chill for at least 30 minutes to allow the cream to set (it may still run when the tart is cut, but it's still delicious)
- Slice and serve!
