Introduction: D4E1 Streetjet Lever Aid
This project is a schoolproject made by 3 last years industrial design students and 1 occupational therapy
student.
Our cliënt has been diagnosed with Ehlers-Danlos syndrome. She uses a wheelchair to move around and for long distances she uses her streetjet with it. Because of her disease it’s difficult to bend over, it makes her struggle to operate the safety lever. After a long and difficult proces we came with a final solution that solves the problem and answers her demands.
- 3D-printer (ABS)
- a brake cable
- asteel rod with a diameter of5 mm
- 4 M5-bolts
- spring 50mm (20Newton)
pipe clambe with a M8 bolt(50 mm)
M8-bolt
Step 1: Remove the Red Lever
Step 2: 3D-print the Parts.
Step 3: Attach the Part "beugel Bovendeel" to the Handlebar With the Existing Bolts. Attach the Lever to the Part With the 4 M5 Bolts.
Step 4: Attach the Part "houder Kabel" Where the Lever Was Originally
Step 5: Place Pipe Clamb Together With the "bushing2 and Kabelhouder Stuur "parts With the M8 Bolt on the Streetjet As Shown in the Picture
Step 6: Bend the Steel Rod
Step 7: Place the Cable and the Steel Rod on the Parts.
- Attach the steel rod with "bushing 2" part on the lever
- Connect the steel rod and the brake cable with the "connector staaf" part
- connect the end of the brake cable with the spring on the streetjet (see picture)
