Introduction: Stress-destroyer 2000
About: I am a middle schooler that loves to craft things and build things! I have 3 cats and 1 dog! Please show your support to my brother! His username is ZabuCatface
If you are stressed out, the best way to calm down is by popping bubble wrap? Make this to use just enough when you need it, and a simple little craft!
Tiny clay/baking roller.
Scissors
Old small Amazon box.
Ballon
Bubble wrap
Tape
Marker (optional)
Step 1: The Box.
You need to cut out 3 of the edges with scissors but leave 1 of the smaller ones. Draw happy drawings on the outside of the box if you want.
Step 2: The Bubble Wrap.
Get the roller and tape it onto the flap on the box. Now measure how long the width of the roller. Now cut the bubble wrap into strips the same width as the roller. Now tape the end of the bubble wrap to the roller. Roll the bubble wrap up.
Step 3: Stress Ball.
Blow air into a ballon. Then let it out. Now put water into the balloon. Dry it with paper towel. Now bring it to you box. Tie a string around the top of the balloon. Now tape the other part of the string to the box.
Step 4: Destroying Stress.
For this step you will cut a piece of paper into a bunch of little pieces. Now get the cut off sides of the book. Cut them into organizers and put them in the middle. Now, If you ever have something your stressed about but have no control over it, write it on one of the long pieces of paper. Now, cut them up and rip them. This makes you feel better.
Step 5: How to Use It.
First, write your problem on the paper. Now put the paper under the stress ball. Press down on the ball onto the paper. Think of this as hurting your problem. Now put the paper on the other side of the bubble wrap. Pop the bubble wrap, and think of this as hurting your problem more. Now, cut the paper up for the final blow. Your problem is destroyed! Now, don’t think of your problem. If you do, repeat this process. Do this whenever you have stress! I hope you a stress less year!
Step 6: Thank You!
I hope you liked this craft! It really helps! Be sure to scroll down and press the vote now button and leave a good comment! Above this is a stress less cat! I hope you all have a stress less year!
