Introduction: Stretch Vinyl Womens 80s Retro Gym Shorts
Checkout how to make a pair of stretch vinyl womens 80's retro gym shorts.
These are great for Cosplay, Barbie themed costumes, or just strapping on roller skates and grabbing your audio-cassette player for a stroll!
Step 1: Gather Your Supplies
Gym shorts sewing pattern (custom to your measurements):
http://www.mjtrends.com/pattern/womens/gym-shorts
Pink and white vinyl fabric:
http://www.mjtrends.com/categories-Stretch-PVC,Fab...
Elastic:
http://www.mjtrends.com/products.Sport-1-inch,Elas...
Thread:
Step 2: Cut Out the Pattern Pieces
Layout your fabric on top of your cutting mat. Place your pattern on top of your fabric, ensure that the greatest amount of stretch runs horizontally across the pattern. Cut out both the pattern pieces and your fabric.
** Use either sewing weights or a couple small heavy objects to keep your pattern in place while cutting it out.**
Step 3: Sew Center Seams for Front and Rear
With right sides together, sew the front center seam, then sew the rear sections through the center.
Step 4: Sew Inner Leg Seams
With right sides together and the front folded onto the rear, sew the inner leg inseams.
Step 5: Cut Out the Trim
If you are using vinyl or latex for the trim, we recommend cutting the trim material at this step. If you are using bias tape, then you can skip this step. Layout your shorts on a cutting mat and trace the curvature of the leg to cut out the trim. See images:
Step 6: Attach the Trim
If using bias tape, then pin your bias tape to the outside leg sections. Sew the bias tape removing pins as you go.
If using latex or vinyl fabric, then sew the trim directly on top of the outside leg sections. See image below:
Step 7: Sew the Leg Seams
Sew down the side leg seam. Sew the other side of the bias tape that doesn't have the stitching from where you originally sewed the bias tape down. Stop at the beginning of the curve at the end of the leg.
Step 8: Sew the Waistband
Fold over the waistband by 1/4 of an inch and sew it down. This
will create a finished edge for the top and inside of the waistband.Using a 3 step zig zag stitch (stretch stitch) or zig-zag stitch if the stretch stitch is not available on your machine, stretch and sew 3 strips of elastic to the inside of the waistband below the folded over area that you just stitched. Stitch in the middle of the elastic.
Step 9: Sew Waistband to Shorts
- Pin the waistband to the shorts and start at the rear seam and
extend past the seam by 1/4 inch. Extend by another 1/4 inch at the end.
Sew the waistband to the shorts, removing the pins as you go.
Due to the stiffness of vinyl, we fold down the waistband-to-shorts seam and top stitch it to force the seam to lay flat. This may be unnecessary with other fabrics.
Stitch the waistband together along the 1/4 inch overlay, with the seam matching up with the rear seam.
Below is an image of the waistband attached to shorts just before sewing the rear waistband seam.
