Introduction: Strider Camera Robot V2
About: Make it yourself if you cannot buy one ;)
This is a simplified version of Strider Camera Robot.
This design avoid to use thin wall bearing and use paperclip as rod, so it can reduce the difficultly of get the material, reduce the cost to build and also reduce the weight.
This instructables mainly cover how to assembly the new version of 3D printed model. More other details can be find at Strider Camera Robot.
Two 4.3g servo:
https://www.aliexpress.com/wholesale?SearchText=4.3g+servo
Some Paperclip:
https://www.aliexpress.com/wholesale?SearchText=33mm+paper+clip
100 pieces of M1.4x4mm pan head bolt:
https://www.aliexpress.com/SearchText=M1.4+pan+head+bolt
Step 1: 3D Printed Parts
Download and 3D print all the parts at thingiverse:
https://www.thingiverse.com/thing:4977235
Note:
The file name tail with "_x2" means print 2 copies ... "_x12" means print 12 copies.
Step 2: Servo Patch
We need to patch two 4.3g servos into gear motors and reduce the size foot print:
  • picture 1: unscrew the servo
  • picture 2: remove the stickers and bottom cover
  • picture 3: detach the potentiometer from the main axis
  • picture 4: optional, if the servo is not 360 rotation model, desoldering motor from control board
  • picture 5: use marker mark the cut out area
  • picture 6: trim the bottom cover
  • picture 7-8: screw up the trimmed bottom cover
  • picture 9-10: trim the main body
  • picture 11-12: trim the main axis tail
Step 3: Install Motor Mount
Use 2 servo screws install to the servo mount. Remember the main axis should be in the middle.
Step 4: Build Paperclip Crankshaft
This is the most difficult parts in this intructables:
  • Picture 1-2: install the smallest servo arm to the main axis
  • Picture 3: unscrew to make a gap that can fit a paperclip
  • Picture 4-5: unbent the paperclip to straight line
  • Picture 6: bend a 1 mm right angle on the straighten paperclip
  • Picture 7-10: fix paperclip to the servo arm and screw up
  • Picture 11-12: mark the paperclip from axis at 6.5 mm, 14 mm, 20.5 mm, 27 mm, 34.5 mm, 41 mm, 47.5 mm, 55 mm, 61.5 mm
  • Picture 13: unscrew the paperclip
  • Picture 14-16: use a wire bending plier bend the wire on all marked point
  • Picture 17: roughly adjust the bent paperclip look like a crankshaft
  • Picture 18: cut the tail at around 2 mm
  • Picture 19: screw up the crankshaft to the servo
  • Picture 20: double check the crankshaft fixed on the servo
Step 5: Fine Tune Crankshaft
Use plier fine tune the crankshaft. The tuning steps are a little bit arbitrary, few points can be highlighted:
  • 3 arms are divided the circle evenly, i.e. 120 degree from arm to arm
  • align main axis and 3 arm poles in the same line
  • double check the tuning by motor turning
Step 6: Legs Assembly Part1
Picture 1-2: connect leg3 and leg4 with screw
Picture 3-4: connect leg2 and leg4 with screw
Picture 5: repeat above step to create 6 legs (12 for both sides)
Step 7: Install Legs to Crankshaft
Step 8: Legs Assembly Part2
Picture 1: connect leg2, leg3 and leg1 with screw
Picture 2: use same method connect other 5 legs
Picture 3: cut 2 pieces straighten paperclip at around 4.75 mm (4 pieces for 2 sides)
Picture 4: stream the paperclip axis to 3 leg1
Picture 5: use same method stream other 3 leg1 and align the paperclip to body1 hole
Picture 6: align body2 holes to crankshaft and 2 paperclip axis
Picture 7: screw up body2 and cover
Step 9: Check Leg Assembly
Check the leg assembly by a slow motor turning.
Step 10: Enjoy!
The legs assembly parts is finished. You can refer Strider Camera Robot for the circuit and software part.
Note: the bottom part of this version can fit a 702535 Lipo, or you can adjust the parts to fit a bigger Lipo.
