How to Make Strike Anywhere Matches
Intro: How to Make Strike Anywhere Matches
You will need: Safety matches (with matchbox), sanding paper, a small container, something to stir with, a pair of pliers, a tube or a D-cell battery, and water.
You will also need something to lay the matches on, like a the edge of a table or this CD case that I used.
STEP 1: Sanding of Phosphorus
Sand off the phosphorus on the sides of the matchbox (striking surfaces) and put the powder in the container.
STEP 2: Put on the Phosphorus
Put a few drops if water in the container and stir well. Take the matches, one by one, and dip them in the mixture. Then lay them on the edge of the table/CD case.
STEP 3: Cover the Phosphorus
When they're dry, take some new matches and squeeze off the heads with the pliers, then pulverize the powder with the pipe or battery by pressing it down and rolling it over the powder and then put it in the container (if you're using the same container, be sure to wash out the leftover phosphorus). Add a few drops of water and stir well. Then dip the matches in the new mix so that you cover the phosphorus already on them and let them to dry again for a while.
STEP 4: Test
STEP 5: Warning
Please be sure to wash your hands after making these matches, phosphorus is toxic.
150 Comments
JamesY23 8 years ago
Okay, you know you can buy strike anywhere matches, don't you? You do not have to go through this. Buy a bunch of them and store them in dry boxes, containers. I've been reading many of your posts and I can't help but wonder why you make so many simple things seem so complicated.
KnightAngel 1 year ago
ancientchildvii 2 years ago
Arbormakes 3 years ago
THEMONEY 7 years ago
Buy some of those "strike anywhere" matches you speak of and try to strike them on a rock or the seat of your pants.
OH2BIO 7 years ago
Well. These are not available in Finland either. I think that these amay be banned in EU, but not sure. I'd like to buy those but it's not possible to ship them from the States to Finland. At least it is very expensive because of strict safety regulations.
artenlor 7 years ago
That's sad because strike any where matches are one of the ingredients in the orginal Molotov Cocktails that were developed in Finland, you should complain based on a historical and patriotic interest.
OH2BIO 7 years ago
As far as I know, Finnish Molotov Cocktail had 12cm long, 60 second Storm Matches (Bengali Stick), not strike anywhere matches. Those would have been really dangerous. There were two sticks. The other was a spare one if you didn't have to throw the bottle on the first time. These Bengali Flares were stiked using matchbox striking surface.
DiabolicusR 8 years ago
Somehow, I think survival after civilization's fall will be quite simple for you, hmmm?
DIYWEAPONS 8 years ago
I hope you realise james that many countries do not produce strike anywhere matches.
Benjizee 8 years ago
tempe.az.blk 2 years ago
Don't sand the Red Phosphorus. Use 100% pure acetone, no dies, no conditioners, no additives at all. Also known as finger nail polish remover. Extremely Flammable, Fumes High Volition. Dip the striking strip for
wwwapexmatchcom 8 years ago
it's so simple. Buy dont try this at home...
Store them in a nice container and keep them for use later.
davidthefrog 7 years ago
hi! to be clear what the article is about is turning 'safety matches' into friction matches, its not the Victorian recipe for 'strike anywhere matches' , so they wont strike on your silver or gold vesta cases ('match safe' if you're reading this in American.
BenjaminS113 7 years ago
Cole Rorich 8 years ago
could you could use metholated spirits instead of water to reduce the drying time?
3nertia 7 years ago
Not sure the phosphorous would dissolve in alcohol
f1dd13r 7 years ago
fantastic I am going to try this. I was just looking at the cost of buying some on ebay and it was ridiculous..£3 for a few little matches
buy swan matches at your local Morrisons for £1 per 4 box pack.
